No dzvents log on the domoticz log page [SOLVED]
snellejellep
- Domoticz version: 2020.2
For some time now, i do not seem to get any dzvents log messages in my log, which i previously did get.
I view my log from settings > log in the web interface.
someone else having this problem?
i have it for a couple of months now and updated to various betas, now running the current latest V4.10547 but it still does not seem to work.
i even changed the loglevel for dzvents in the settings to debug but that does not seem to make any difference.
i hope someone can help me.
- waaren
Re: No dzvents log on the domoticz log page
Can you share your /etc/init.d/domoticz.sh ?snellejellep wrote: Saturday 16 March 2019 19:46 Hi,
Do you select "All" at the log tab ?
Did you cleared cache and appcache after the last update ?
snellejellep
i did all of that, this is my domoticz.sh: https://snellejellep.stackstorage.com/s/yM59Njojl26eliewaaren wrote: Saturday 16 March 2019 21:41 Can you share your /etc/init.d/domoticz.sh ?
- waaren
Can you try to change the current linesnellejellep wrote: Monday 18 March 2019 17:56i did all of that, this is my domoticz.sh: https://snellejellep.stackstorage.com/s/yM59Njojl26eliewaaren wrote: Saturday 16 March 2019 21:41 Can you share your /etc/init.d/domoticz.sh ?
DAEMON_ARGS="$DAEMON_ARGS -log /tmp/log/domoticz.log -loglevel normal"
and make it
DAEMON_ARGS="$DAEMON_ARGS -log /tmp/log/domoticz.log"
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error"When stopping domoticz you will see a message like
Warning: domoticz.service changed on disk. Run 'systemctl daemon-reload' to reload units.Code: Select all
sudo systemctl daemon-reload Debian buster, bullseye on RPI-4, Intel NUC.
snellejellep
Re: No dzvents log on the domoticz log page [SOLVED]
Thank you, this works but am i supposed to get dzvents debug log messages? i do not remember getting those but that may be new.waaren wrote: Monday 18 March 2019 18:08Can you try to change the current linesnellejellep wrote: Monday 18 March 2019 17:56i did all of that, this is my domoticz.sh: https://snellejellep.stackstorage.com/s/yM59Njojl26eliewaaren wrote: Saturday 16 March 2019 21:41 Can you share your /etc/init.d/domoticz.sh ?
Did you cleared cache and appcache after the last update ?in /etc/init.d/domoticz.shCode: Select all
and make itafter that stop and start domoticz (a restart might not be enough to pick up these changes).Code: Select all
DAEMON_ARGS="$DAEMON_ARGS -log /tmp/log/domoticz.log" DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error"
When stopping domoticz you will see a message likeThis is normal behavior. Just do aCode: Select all
Warning: domoticz.service changed on disk. Run 'systemctl daemon-reload' to reload units.to reload them before giving the start command (only needed once).Code: Select all
- waaren
dzVents Log Level is controlled separately:snellejellep wrote: Monday 18 March 2019 19:16 Thank you, this works but am i supposed to get dzvents debug log messages? i do not remember getting those but that may be new.
using the domoticz web GUI interface: choose [setup] [settings] [other] and at the bottom you will find the dzVents Log Level where you can pick one of the 5 different levels
snellejellep
Right, i ineed changed that in trying to fix the issue. Massive thanks!
Verstuurd vanaf mijn SM-G975F met Tapatalk
