Did you resubscribe? If so, msg me from Controlicz and I’ll get you working again
- Domoticz version: 2023.2
disable/enable skill
working now
working now
Hi Madgeni, just a quick feeback as I'm back home.
After re suscribe with new user and reactivate skills everything is ok !!
And really... thanx for keeping it running, that's a very good news
Account: french.......hotmail
Pliease help me with my Controlicz subscription: I reregistered, but the subcription fee is reservedd on my creditcard account, but my Contolicz account remains free and I cannot use voice control via DomoticzMadgeni wrote: ↑Monday 28 August 2023 11:12 Hi all - for those that weren't aware, i've decided to keep Controlicz running. I've made changes to it to allow for the newer Domoticz versions (aligned changes to auth and API calls).
If you've lost access, it's highly likely it's due to an annual subscription expiring. I stopped them this year, so that people didn't pay for a service which was going to no longer be running. It's likely you had some free usage of Controlicz before i enforce expiration.
You will need to create a new account and subscribe monthly for now.
Yes, same here...
Also when testing the connection i get this in the Domoticz log:
It all used to work fine until i had to re-register again.... any ideas?
2023-10-17 12:10:54.553 Error: [web:443] Failed authentication attempt, ignoring client request (remote address: 35.178.116.149)
As per support mail, this is a 3d secure issue with your card provider. If you use PayPal you should be finenahoj wrote: ↑Monday 09 October 2023 14:09Pliease help me with my Controlicz subscription: I reregistered, but the subcription fee is reservedd on my creditcard account, but my Contolicz account remains free and I cannot use voice control via DomoticzMadgeni wrote: ↑Monday 28 August 2023 11:12 Hi all - for those that weren't aware, i've decided to keep Controlicz running. I've made changes to it to allow for the newer Domoticz versions (aligned changes to auth and API calls).
Failed auth attempts on Domoticz side, check basic-auth is set, and/or restart Domoticz (which refreshes security model afaik).JimmyH1969 wrote: ↑Tuesday 17 October 2023 12:14 Yes, same here...
Also when testing the connection i get this in the Domoticz log:It all used to work fine until i had to re-register again.... any ideas?Code: Select all
Sometimes it's so simple... all working fine now. Thank you!Madgeni wrote: ↑Tuesday 17 October 2023 12:18Failed auth attempts on Domoticz side, check basic-auth is set, and/or restart Domoticz (which refreshes security model afaik).JimmyH1969 wrote: ↑Tuesday 17 October 2023 12:14 Yes, same here...
- Domoticz version: Dev
Since some time (guess around 1-2 weeks) Google is not connecting to Controlicz anymore. Controlicz connection to Domotucz is fine (test connection says all is ok and device status is nicely updated in controlicz when I make a change from domoticz). Anything that I can check? Known issue? Google updating their API's?
RPi 3, Domoticz dev version, Aeon ZWave stick (with a whole bunch of slaves), Zigbee using Zigbee2MQTT, Nest thermo, P1 smart meter on RPi Zero
hi - sorry, only just seen this. all is fine with Controlicz - hopefully you resolved this (maybe subscription?) , but if not, drop me a support email from Controlicz, and i'll see what's happening
Indeed it still is an issue. Dropped a note via controlicz as requested.
- Varazir
Anyone ells having issue with Controlicz? It's not working. Webpage say ok on test but google say my devices are offline and trying to re-authenticate I get a error saying it can't contact Controlicz
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Working for me
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
- Varazir
Hmm strange.
- Varazir
Tried to remove and add it again and got the same error
Late to this, but best thing is to msg me via Controlicz profile. Also, check your test works ok, and you can see your devices in your profile
- Varazir
I sent a msg on the Controlicz webpage but I haven't heard anything back.
Hi - I don’t seem to have received one. What’s the issue?
Are you able to access Domoticz remotely? Does the test work?
