Long delay on Google Home voice notifications Topic is solved
Alexa, Google Home and Siri
Sherlock
Domoticz version: 4.10717
Post by Sherlock »
I am using Node-Red to send a voice notification to my Google Home Mini when a doorbell is pushed in Domoticz.
This set-up with the Google Home Notify node is working allright but it seems to me there is a long delay between the moment of pressing the doorbell and the actual spoken notification on the Google Home Mini (approx. 7-8 seconds). Not so very effective.
When I output the message via the Play Audio node, the audio message comes through immediately (on my monitor in this case).
Obviously the route to the Google servers and the translation from text-to-speech (TTS) is taking a long time.
My question is: 1. Are there more users with the same experience? and 2. Is there is a solution for this behaviour?
The Node-Red flow I am using:
[{"id":"13e317fc.3295e","type":"tab","label":"Flow 4","disabled":false,"info":""},{"id":"617706bf.40a8e","type":"mqtt in","z":"13e317fc.3295e","name":"","topic":"domoticz/out","qos":"2","datatype":"auto","broker":"da355387.6ab0e8","x":130,"y":180,"wires":[["b4e236bf.60b238"]]},{"id":"c716740f.d9cb5","type":"switch","z":"13e317fc.3295e","name":"","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"47","vt":"num"},{"t":"eq","v":"53","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":430,"y":180,"wires":[["7fd7a2b8.c6210c","6d3a12e5.c7694c"],[]]},{"id":"7fd7a2b8.c6210c","type":"debug","z":"13e317fc.3295e","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":610,"y":174,"wires":[]},{"id":"b4e236bf.60b238","type":"json","z":"13e317fc.3295e","name":"","property":"payload","action":"","pretty":false,"x":290,"y":180,"wires":[["c716740f.d9cb5"]]},{"id":"cb54564d.210728","type":"play audio","z":"13e317fc.3295e","name":"","voice":"1","x":650,"y":240,"wires":[]},{"id":"6d3a12e5.c7694c","type":"change","z":"13e317fc.3295e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"front door","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":240,"wires":[["fe164df4.ceead8"]]},{"id":"fe164df4.ceead8","type":"googlehome-notify","z":"13e317fc.3295e","server":"b24bbd5a.8161b8","name":"","x":680,"y":300,"wires":[]},{"id":"da355387.6ab0e8","type":"mqtt-broker","z":"","name":"mqtt broker testpi","broker":"0.0.0.0","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"b24bbd5a.8161b8","type":"googlehome-config-node","z":"","ipaddress":"0.0.0.0","name":"","language":"nl"}]
xury
Re: Long delay on Google Home voice notifications
Post by xury »
Maybe you should try using node-red-contrib-cast, or node-red-contrib-castv2 instead.
I use it and I have no delay.
Sherlock
Post by Sherlock »
Hi xury,
Thank you for your reply.
I think I have used the node-red-contrib-cast ( I am not at home now, so I am not sure).
But maybe you can post me the flow you have used. That way I can see how you solved it.
Thank you
Last edited by Sherlock on Saturday 21 December 2019 11:18, edited 1 time in total.
Sherlock
Post by Sherlock »
Hi xury,
When i am using node-red-contrib-cast (in a simple flow), I still have a delay of approx. 7-8 seconds before spoken text is heard on google home mini.
This is the flow I am using:
[{"id":"1f26932b.529805","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"264837.d64f07ca","type":"cast-to-client","z":"1f26932b.529805","name":"","url":"","contentType":"","message":"hallo","language":"nl","ip":"192.168.0.10","port":"","volume":"","x":600,"y":300,"wires":[[]]},{"id":"38b9a56.1d057da","type":"inject","z":"1f26932b.529805","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":400,"y":300,"wires":[["264837.d64f07ca"]]}]
