Google Home vs. Amazon Alexa? Topic is solved
I have been a satisfied user of Alexa for two years. Now, google is coming with Home in my language. Should I give it a go? Time to switch?
What are your thoughts?
- heggink
- Domoticz version: 12451
Re: Google Home vs. Amazon Alexa?
I switched. The mini is a lot smarter and more accessible.
P1 meter & solar panel
Hesmink
How do the both compare in Domoticz support?
Stief
You can use Controlicz or ITTT to integrate Domoticz with Google Home (and the Google assistant) I have no experience with Alexa buth read somewhere that Alexa also supports both.
I myself am using a KaKu ICS-2000 for the integration. I don't want my Domoticz setup available from internet. Some people use muliple Domoticz instances/ devices for that so they have only one with limited functions extern accessable.
As written above I use a KaKu ICS-2000 wich I got cheap online. KaKu (or Trust) has native support for Google Home. Made a few groups on my domoticz for certain devices I want to be able to controll with Google Home. Whitin the groups I added a activation device that I created on the Kaku for this.
So I have only the devices/switches I want to operate with Google Home created on the KaKu and my Domoticz isolated from internet.
I really enjoy the alexa speak option, that came available in 2018.
Can you also make Google speak?
- heggink
Absolutely and without issues like caption...
bozidar
i have both the google mini and the echo dot . use it with Domoticz thru controlicz .
I am seeing much longer "reaktion times" with the mini than the Echo.
Do any of you have same experiences ?
- heggink
Not in my case... Letting Google talk is much faster.
ricorico94
Hi Heggink,
Could you describe which solution you use for Google Home Mini ? Is it controlicz ? If yes, it's not free anymore, correct ?
br,
Ricorico94
br,
Ricorico94
