I have a strange issue I don't know how to fix. I have bought 4 identical Zigbee devices (TS011F-din) and plugged one pair into each of my two Domoticz instances.
On one of them they are recognized as simple switches, on the other (done with an earlier version 6 month ago) they are correctly identified as Switch/Power/Meter/Voltage
I tried re-associating the wrong ones after upgrading the plugin to the latest version.... same result.
Any idea? I suspect a regression in the latest version as it worked fine on the old one, and not on my newly reinstalled one.
Blaise
Same Zigbee device detected differently on two Domoticz instances (Z4D) Topic is solved
- Target OS: -
Re: Same Zigbee device detected differently on two Domoticz instances
Hello, wich one zigbee plugin ?
I'm using https://github.com/zigbeefordomoticz/Domoticz-Zigbee, version May 2024 - stable7.1.012 ( 2024.04)
Blaise
Blaise
- Domoticz version: 2024.7
You have to check the zigbee details of the devices. Could be that the tuya Manufacturing ID (eg _TZ3000_okaz9tjs) is different between the models. Also check in the zigbee4Domoticz UI if the new device is listed as certified.
Re: Same Zigbee device detected differently on two Domoticz instances (Z4D)
The device is certified. I tried re appairing the units. Surprisignly one was then identified as TS011F-din and the other as TS011F. Both are DIN mounted. The one identified as DIN now has all the sensors, the other one is still seen as just a switch. Both are identified as _TZ3000_qeuvnohg
I've just received two more units.... I'll see how they behave.
Thanks for the hints anyway
Perhaps report that to the zigbee4Domoticz certified devices repository, see below how to do that.
https://zigbeefordomoticz.github.io/wik ... evice.html
