ZiGate_v3.20-OPDM, Zigate not correctly initialized Topic is solved
marktn
Post by marktn »
I have updated to the 3.20 OPDM version. Flashing worked fine. full Erase EEPROM and Erase PDM done.
Update the plugin to latest version.
But i did get a error, what to do?
 2021-09-10 20:33:23.146 [GCC 8.3.0]
2021-09-10 20:33:23.146 Status: Zigate: (Zigate) [ MainThread] DomoticzVersion: 2021.1
2021-09-10 20:33:23.146 Status: Zigate: (Zigate) [ MainThread] DomoticzHash: 8547c5b7e
2021-09-10 20:33:23.146 Status: Zigate: (Zigate) [ MainThread] DomoticzBuildTime: 2021-04-17 17:29:11
2021-09-10 20:33:23.146 Status: Zigate: (Zigate) [ MainThread] Opening DomoticzDB in raw
2021-09-10 20:33:23.166 Status: Zigate: (Zigate) [ MainThread] Plugin Database: DeviceList-16.txt
2021-09-10 20:33:23.176 Status: Zigate: (Zigate) [ MainThread] DeviceConf loaded
2021-09-10 20:33:23.285 Status: Zigate: (Zigate) [ MainThread] load ListOfDevice
2021-09-10 20:33:24.149 Status: Zigate: (Zigate) [ MainThread] 39 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-16.txt
2021-09-10 20:33:24.253 Status: Zigate: (Zigate) [ MainThread] Transport mode: USB
2021-09-10 20:33:24.255 Status: Zigate: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
2021-09-10 20:33:24.268 Status: Zigate: (Zigate) [ MainThread] ZigateTransport: Serial Connection open: Serial<id=0x66ef1a70, open=True>(port='/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2021-09-10 20:33:24.269 Status: Zigate: (Zigate) [ZiGateWriter_16] ZigateTransport: writer_thread Thread start.
2021-09-10 20:33:24.270 Status: Zigate: (Zigate) [ZiGateForwarder_16] ZigateTransport: thread_processing_and_sending Thread start.
2021-09-10 20:33:24.272 Status: Zigate: (Zigate) Connection open: Serial<id=0x66ef1a70, open=True>(port='/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2021-09-10 20:33:24.382 Status: Zigate: (Zigate) [ZiGateSerial_16] ==> Transport Mode switch to: 31e
2021-09-10 20:33:24.385 Status: Zigate: (Zigate) [ZiGateForwarder_16] ZiGate V2
2021-09-10 20:33:24.385 Status: Zigate: (Zigate) [ZiGateForwarder_16] Installer Version Number: 0320
2021-09-10 20:33:33.071 Error: Zigate: (Zigate) Zigate not correctly initialized
2021-09-10 20:33:38.080 Error: Zigate: (Zigate) Zigate not correctly initialized
2021-09-10 20:33:41.575 Status: Zigate: (Zigate) Stop directive received.
2021-09-10 20:33:41.575 Status: Zigate: (Zigate) [ MainThread] onStop called
2021-09-10 20:33:41.576 Status: Zigate: (Zigate) Connection close: Serial<id=0x66ef1a70, open=True>(port='/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2021-09-10 20:33:41.577 Status: Zigate: (Zigate) [ZiGateSerial_16] ZigateTransport: ZiGateSerialListen Thread stop.
2021-09-10 20:33:41.577 Status: Zigate: (Zigate) [ZiGateWriter_16] ZigateTransport: writer_thread Thread stop.
2021-09-10 20:33:41.577 Status: Zigate: (Zigate) [ZiGateForwarder_16] ZigateTransport: thread_processing_and_sending Thread stop.
2021-09-10 20:33:41.779 Status: Zigate: (Zigate) Statistics on message
2021-09-10 20:33:41.779 Status: Zigate: (Zigate) ZiGate reacting time
2021-09-10 20:33:41.779 Status: Zigate: (Zigate) Max : 11 sec
2021-09-10 20:33:41.779 Status: Zigate: (Zigate) Average : 9 sec
2021-09-10 20:33:41.779 Status: Zigate: (Zigate) ZiGate processing time on Rx
2021-09-10 20:33:41.779 Status: Zigate: (Zigate) Max : 1 sec
2021-09-10 20:33:41.779 Status: Zigate: (Zigate) Average : 0 sec
2021-09-10 20:33:41.779 Status: Zigate: (Zigate) Sent:
2021-09-10 20:33:41.779 Status: Zigate: (Zigate) TX commands : 3
2021-09-10 20:33:41.780 Status: Zigate: (Zigate) Max Load (Queue) : 0
2021-09-10 20:33:41.780 Status: Zigate: (Zigate) Max aPDU (Queue) : 0
2021-09-10 20:33:41.780 Status: Zigate: (Zigate) Max nPDU (Queue) : 0
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) TX failed : 0 (0.0%)
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) TX timeout : 0 (0.0%)
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) TX data timeout : 0 (0.0%)
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) TX reTransmit : 0 (0.0%)
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) TX APS Failure : 0 (0.0%)
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) TX APS Ack : 0 (0.0%)
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) TX APS Nck : 0 (0.0%)
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) Received:
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) RX frame : 6
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) RX crc errors : 0 (0.0%)
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) RX lentgh errors : 0 (0.0%)
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) RX clusters : 0
2021-09-10 20:33:41.781 Status: Zigate: (Zigate) RX clusters KO : 0
2021-09-10 20:33:41.782 Status: Zigate: (Zigate) Operating time : 0 Hours 0 Mins 17 Secs
2021-09-10 20:33:42.666 Zigate: (Zigate) Device sValue: '88'
2021-09-10 20:33:42.666 Zigate: (Zigate) Device LastLevel: 88
2021-09-10 20:33:42.666 Zigate: (Zigate) Device Options: {}
2021-09-10 20:33:42.666 Zigate: (Zigate) Device: 48 - ID: 4794, Name: '$Woonkamer Eethoek-2', nValue: 1, sValue: '88'
2021-09-10 20:33:42.666 Zigate: (Zigate) Device ID: '4794'
2021-09-10 20:33:42.666 Zigate: (Zigate) Device Name: '$Woonkamer Eethoek-2'
2021-09-10 20:33:42.666 Zigate: (Zigate) Device nValue: 1
2021-09-10 20:33:42.667 Zigate: (Zigate) Device: 49 - ID: 4795, Name: '$Woonkamer Eethoek-3', nValue: 1, sValue: '10'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device ID: '4795'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device Name: '$Woonkamer Eethoek-3'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device nValue: 1
2021-09-10 20:33:42.667 Zigate: (Zigate) Device sValue: '10'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device LastLevel: 10
2021-09-10 20:33:42.667 Zigate: (Zigate) Device Options: {}
2021-09-10 20:33:42.667 Zigate: (Zigate) Device: 50 - ID: 4796, Name: '$Woonkamer Eethoek-4', nValue: 1, sValue: '9'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device ID: '4796'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device Name: '$Woonkamer Eethoek-4'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device sValue: '9'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device LastLevel: 9
2021-09-10 20:33:42.667 Zigate: (Zigate) Device: 51 - ID: 4797, Name: '$Woonkamer Eethoek-5', nValue: 1, sValue: '9'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device ID: '4797'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device Name: '$Woonkamer Eethoek-5'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device: 52 - ID: 4798, Name: 'Woonkamer Eethoek', nValue: 1, sValue: '9'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device ID: '4798'
2021-09-10 20:33:42.667 Zigate: (Zigate) Device Name: 'Woonkamer Eethoek'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device nValue: 1
2021-09-10 20:33:42.668 Zigate: (Zigate) Device sValue: '9'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device LastLevel: 9
2021-09-10 20:33:42.668 Zigate: (Zigate) Device Options: {}
2021-09-10 20:33:42.668 Zigate: (Zigate) Device: 53 - ID: 4862, Name: 'Woonkamer Vloerlamp', nValue: 1, sValue: '10'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device ID: '4862'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device Name: 'Woonkamer Vloerlamp'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device sValue: '10'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device LastLevel: 10
2021-09-10 20:33:42.668 Zigate: (Zigate) Device: 54 - ID: 4938, Name: 'Watersensor Vaatwasser', nValue: 0, sValue: 'Off'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device ID: '4938'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device Name: 'Watersensor Vaatwasser'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device nValue: 0
2021-09-10 20:33:42.668 Zigate: (Zigate) Device sValue: 'Off'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device LastLevel: 0
2021-09-10 20:33:42.668 Zigate: (Zigate) Device: 55 - ID: 4941, Name: 'Voordeur lamp (new)', nValue: 1, sValue: '100'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device ID: '4941'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device Name: 'Voordeur lamp (new)'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device sValue: '100'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device LastLevel: 100
2021-09-10 20:33:42.668 Zigate: (Zigate) Device: 56 - ID: 4953, Name: '$Hal-lift', nValue: 1, sValue: '43'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device ID: '4953'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device Name: '$Hal-lift'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device sValue: '43'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device LastLevel: 43
2021-09-10 20:33:42.668 Zigate: (Zigate) Device: 57 - ID: 4954, Name: '$Hal-dressoir', nValue: 1, sValue: '43'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device ID: '4954'
2021-09-10 20:33:42.668 Zigate: (Zigate) Device Name: '$Hal-dressoir'
2021-09-10 20:33:42.669 Zigate: (Zigate) Device LastLevel: 43
2021-09-10 20:33:42.669 Zigate: (Zigate) Device Options: {}
2021-09-10 20:33:42.669 Zigate: (Zigate) Device: 58 - ID: 4988, Name: 'Zigate - TS0601-sirene_TuyaSirenTemp-804b50fffe047063-01', nValue: 0, sValue: ''
2021-09-10 20:33:42.669 Zigate: (Zigate) Device ID: '4988'
2021-09-10 20:33:42.669 Zigate: (Zigate) Device Name: 'Zigate - TS0601-sirene_TuyaSirenTemp-804b50fffe047063-01'
2021-09-10 20:33:42.669 Zigate: (Zigate) Device nValue: 0
2021-09-10 20:33:42.669 Zigate: (Zigate) Device sValue: ''
2021-09-10 20:33:42.669 Zigate: (Zigate) Device LastLevel: 0
2021-09-10 20:33:42.669 Zigate: (Zigate) Device Options: {'LevelActions': '|', 'LevelNames': 'Off|Alarm Temperature', 'LevelOffHidden': 'false', 'SelectorStyle': '1'}
2021-09-10 20:33:42.669 Zigate: (Zigate) Device: 59 - ID: 4989, Name: 'Zigate - Zigate Notifications 16', nValue: 0, sValue: 'Zigate IEEE: 00158d0001ee040a'
2021-09-10 20:33:42.669 Zigate: (Zigate) Device ID: '4989'
2021-09-10 20:33:42.669 Zigate: (Zigate) Device Name: 'Zigate - Zigate Notifications 16'
2021-09-10 20:33:42.669 Zigate: (Zigate) Device sValue: 'Zigate IEEE: 00158d0001ee040a'
2021-09-10 20:33:42.669 Zigate: (Zigate) Device: 65 - ID: 4968, Name: '$Hal-deur', nValue: 1, sValue: '43'
2021-09-10 20:33:42.669 Zigate: (Zigate) Device ID: '4968'
2021-09-10 20:33:42.669 Zigate: (Zigate) Device Name: '$Hal-deur'
2021-09-10 20:33:42.669 Zigate: (Zigate) Device nValue: 1
2021-09-10 20:33:42.669 Zigate: (Zigate) Device sValue: '43'
2021-09-10 20:33:42.669 Zigate: (Zigate) DomoticzVersion: 2021.1
2021-09-10 20:33:42.669 Zigate: (Zigate) Major: 2021 Minor: 1
2021-09-10 20:33:42.012 Status: Zigate: (Zigate) Exiting work loop.
2021-09-10 20:33:42.077 Status: Zigate: (Zigate) Stopping threads.
2021-09-10 20:33:42.077 Status: Zigate: (Zigate) Stopped.
2021-09-10 20:33:42.077 Status: Zigate: (Zigate) Entering work loop.
2021-09-10 20:33:42.077 Status: Zigate: (Zigate) Started.
2021-09-10 20:33:42.635 Status: Zigate: (Zigate) Initialized version 4.12, author 'zaraki673 pipiche38'
2021-09-10 20:33:42.656 Status: Zigate: (Zigate) Zigate plugin beta-4.12.107 started
2021-09-10 20:33:42.656 Status: Zigate: (Zigate) Debug: 14
2021-09-10 20:33:42.669 Status: Zigate: (Zigate) load PluginConf
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) enablegroupmanagement set to 1
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) channel set to 11
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) forceAckOnZCL set to True
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-16.json
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) debugInput set to 1
2021-09-10 20:33:42.675 Status: Zigate: (Zigate) debugCluster set to 1
2021-09-10 20:33:42.676 Status: Zigate: (Zigate) debugPairing set to 1
2021-09-10 20:33:42.676 Status: Zigate: (Zigate) debugTuya set to 1
2021-09-10 20:33:42.676 Status: Zigate: (Zigate) debuginRawAPS set to 1
2021-09-10 20:33:42.676 Status: Zigate: (Zigate) forceAckOnZCL set to True
2021-09-10 20:33:42.676 Status: Zigate: (Zigate) [ MainThread] Python Version - 3.7.3 (default, Jul 25 2020, 13:03:44)
2021-09-10 20:33:42.676 [GCC 8.3.0]
2021-09-10 20:33:42.676 Status: Zigate: (Zigate) [ MainThread] DomoticzVersion: 2021.1
2021-09-10 20:33:42.676 Status: Zigate: (Zigate) [ MainThread] DomoticzHash: 8547c5b7e
2021-09-10 20:33:42.677 Status: Zigate: (Zigate) [ MainThread] DomoticzBuildTime: 2021-04-17 17:29:11
2021-09-10 20:33:42.677 Status: Zigate: (Zigate) [ MainThread] Opening DomoticzDB in raw
2021-09-10 20:33:42.698 Status: Zigate: (Zigate) [ MainThread] Plugin Database: DeviceList-16.txt
2021-09-10 20:33:42.707 Status: Zigate: (Zigate) [ MainThread] DeviceConf loaded
2021-09-10 20:33:42.817 Status: Zigate: (Zigate) [ MainThread] load ListOfDevice
2021-09-10 20:33:43.902 Zigate: (Zigate) Zigate command round trip 0x8000 Max: 9 ms with an of average: 9 ms
2021-09-10 20:33:43.903 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: 99, Data: 0000001000000000, LQI: 0
2021-09-10 20:33:43.905 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8010, MsgLength: 0005, MsgCRC: b2, Data: 00040320, LQI: 0
2021-09-10 20:33:43.905 Zigate: (Zigate) [ZiGateForwarder_16] Decode8010 - Reception Version list : 00040320
2021-09-10 20:33:43.676 Status: Zigate: (Zigate) [ MainThread] 39 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-16.txt
2021-09-10 20:33:43.774 Status: Zigate: (Zigate) [ MainThread] Transport mode: USB
2021-09-10 20:33:43.776 Status: Zigate: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
2021-09-10 20:33:43.790 Status: Zigate: (Zigate) [ MainThread] ZigateTransport: Serial Connection open: Serial<id=0x66f13bd0, open=True>(port='/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2021-09-10 20:33:43.791 Status: Zigate: (Zigate) [ZiGateWriter_16] ZigateTransport: writer_thread Thread start.
2021-09-10 20:33:43.792 Status: Zigate: (Zigate) [ZiGateForwarder_16] ZigateTransport: thread_processing_and_sending Thread start.
2021-09-10 20:33:43.792 Status: Zigate: (Zigate) Connection open: Serial<id=0x66f13bd0, open=True>(port='/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2021-09-10 20:33:43.902 Status: Zigate: (Zigate) [ZiGateSerial_16] ==> Transport Mode switch to: 31e
2021-09-10 20:33:43.905 Status: Zigate: (Zigate) [ZiGateForwarder_16] ZiGate V2
2021-09-10 20:33:43.905 Status: Zigate: (Zigate) [ZiGateForwarder_16] Installer Version Number: 0320
2021-09-10 20:33:45.127 Slave Synolgy: Light/Switch (Extender-1)
2021-09-10 20:33:49.697 Slave Synolgy: General/Percentage (Unknown)
2021-09-10 20:33:52.102 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: 80, Data: 0000000900000000, LQI: 0
2021-09-10 20:33:52.106 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8009, MsgLength: 0016, MsgCRC: ed, Data: ffff00158d0001ee040a5e5e00000000000000000b, LQI: 0
2021-09-10 20:33:52.106 Zigate: (Zigate) [ZiGateForwarder_16] Decode8009: Network state - Address :ffff extaddr :00158d0001ee040a PanID : 5e5e Channel : 11
2021-09-10 20:33:52.106 Error: Zigate: (Zigate) Zigate not correctly initialized
2021-09-10 20:33:57.109 Zigate: (Zigate) Zigate command round trip 0x8000 Max: 12 ms with an of average: 10 ms
2021-09-10 20:33:57.110 Zigate: (Zigate) Zigate Thread Serial Read Max: 1 ms with an of average: 0 ms
2021-09-10 20:33:57.111 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: 80, Data: 0000000900000000, LQI: 0
2021-09-10 20:33:57.113 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8009, MsgLength: 0016, MsgCRC: ed, Data: ffff00158d0001ee040a5e5e00000000000000000b, LQI: 0
2021-09-10 20:33:57.113 Zigate: (Zigate) [ZiGateForwarder_16] Decode8009: Network state - Address :ffff extaddr :00158d0001ee040a PanID : 5e5e Channel : 11
2021-09-10 20:33:57.113 Error: Zigate: (Zigate) Zigate not correctly initialized
2021-09-10 20:34:02.109 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: 80, Data: 0000000900000000, LQI: 0
2021-09-10 20:34:02.112 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8009, MsgLength: 0016, MsgCRC: ed, Data: ffff00158d0001ee040a5e5e00000000000000000b, LQI: 0
2021-09-10 20:34:02.112 Zigate: (Zigate) [ZiGateForwarder_16] Decode8009: Network state - Address :ffff extaddr :00158d0001ee040a PanID : 5e5e Channel : 11
2021-09-10 20:34:02.112 Error: Zigate: (Zigate) Zigate not correctly initialized
2021-09-10 20:34:07.072 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: 80, Data: 0000000900000000, LQI: 0
2021-09-10 20:34:07.074 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8009, MsgLength: 0016, MsgCRC: ed, Data: ffff00158d0001ee040a5e5e00000000000000000b, LQI: 0
2021-09-10 20:34:07.075 Zigate: (Zigate) [ZiGateForwarder_16] Decode8009: Network state - Address :ffff extaddr :00158d0001ee040a PanID : 5e5e Channel : 11
2021-09-10 20:34:07.057 Error: Zigate: (Zigate) We are having difficulties to start Zigate. Basically we are not receiving what we expect from Zigate
2021-09-10 20:34:07.057 Error: Zigate: (Zigate) Plugin is not started ...
2021-09-10 20:34:07.075 Error: Zigate: (Zigate) Zigate not correctly initialized
2021-09-10 20:34:12.100 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: 80, Data: 0000000900000000, LQI: 0
2021-09-10 20:34:12.103 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8009, MsgLength: 0016, MsgCRC: ed, Data: ffff00158d0001ee040a5e5e00000000000000000b, LQI: 0
2021-09-10 20:34:12.103 Zigate: (Zigate) [ZiGateForwarder_16] Decode8009: Network state - Address :ffff extaddr :00158d0001ee040a PanID : 5e5e Channel : 11
2021-09-10 20:34:12.087 Error: Zigate: (Zigate) We are having difficulties to start Zigate. Basically we are not receiving what we expect from Zigate
2021-09-10 20:34:12.087 Error: Zigate: (Zigate) Plugin is not started ...
2021-09-10 20:34:12.103 Error: Zigate: (Zigate) Zigate not correctly initialized
2021-09-10 20:34:13.584 Slave Synolgy: Light/Switch (Extender-1)
2021-09-10 20:34:17.067 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: 80, Data: 0000000900000000, LQI: 0
2021-09-10 20:34:17.071 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8009, MsgLength: 0016, MsgCRC: ed, Data: ffff00158d0001ee040a5e5e00000000000000000b, LQI: 0
2021-09-10 20:34:17.071 Zigate: (Zigate) [ZiGateForwarder_16] Decode8009: Network state - Address :ffff extaddr :00158d0001ee040a PanID : 5e5e Channel : 11
2021-09-10 20:34:17.054 Error: Zigate: (Zigate) We are having difficulties to start Zigate. Basically we are not receiving what we expect from Zigate
2021-09-10 20:34:17.054 Error: Zigate: (Zigate) Plugin is not started ...
2021-09-10 20:34:17.071 Error: Zigate: (Zigate) Zigate not correctly initialized
2021-09-10 20:34:18.343 EventSystem: Event triggered: Buitenzit weer_2
2021-09-10 20:34:18.359 Dummy: Light/Switch (Buitenzit weer)
2021-09-10 20:34:18.343 Status: buitenzitweer uitgeschakeld
2021-09-10 20:34:19.737 Slave Synolgy: General/Percentage (Unknown)
2021-09-10 20:34:19.754 Slave Synolgy: General/Percentage (Unknown)
2021-09-10 20:34:22.108 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: 80, Data: 0000000900000000, LQI: 0
2021-09-10 20:34:22.111 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8009, MsgLength: 0016, MsgCRC: ed, Data: ffff00158d0001ee040a5e5e00000000000000000b, LQI: 0
2021-09-10 20:34:22.111 Zigate: (Zigate) [ZiGateForwarder_16] Decode8009: Network state - Address :ffff extaddr :00158d0001ee040a PanID : 5e5e Channel : 11
2021-09-10 20:34:22.096 Error: Zigate: (Zigate) We are having difficulties to start Zigate. Basically we are not receiving what we expect from Zigate
2021-09-10 20:34:22.096 Error: Zigate: (Zigate) Plugin is not started ...
2021-09-10 20:34:22.111 Error: Zigate: (Zigate) Zigate not correctly initialized
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
pipiche
Re: ZiGate_v3.20-OPDM, Zigate not correctly initialized
Post by pipiche »
You have to start the plugin with Initialise flag
marktn
Post by marktn »
pipiche wrote: Friday 10 September 2021 20:35 You have to start the plugin with Initialise flag
What do you mean with that? It is a setting is domoticz i gues?
The dashboard is not starting.
marktn
Post by marktn »
marktn wrote: Friday 10 September 2021 20:39
Found it :D
Will initialize ZiGate with the plugin parameters. This is a MUST when using ZiGate the first time (or after an Erase EEPROMO). ATTENTION: Will Erase all pairing information on the Zigate. In such case put it to True and restart the plugin
To be sure, where to find the firmware version in the plugin?
Plugin: 4.12.107
Firmware: 0320 the OPDM version i gues?
keros
Post by keros »
Carefull : the firmware is related to the ZiGate and the plugin is for DomoticZ.
The firmware version is visible at the bottom of the plugin WebUI. It is also written in the plugin starting logs.
For your information, the updates has been stopped on the stable branch. You have to change to the stable5 branch to have de V5.XX.XX update of the plugin.
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
marktn
Post by marktn »
keros wrote: Saturday 11 September 2021 22:00 Carefull : the firmware is related to the ZiGate and the plugin is for DomoticZ.
Thank, just use this command to update? git checkout stable5
Maybe it will also solve my other problem with my Tuya Siren..
keros
Post by keros »
This command doesn't update : it only changes the branch. You have to do a git pull afterwards.
marktn
Post by marktn »
Thanks, update is done, and works. I will continue the Siren in the other topic.
keros
Post by keros »
Good :)
