Zigate Hue gu10 white ambiance Topic is solved
marktn
Post by marktn »
Is there a way to change rgbww to colorswitch ww.
The light has cold and warm white. Only i domoticz it has all the colors.
Mark
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
Domoticz version: 2026.3
Re: Zigate Hue gu10 white ambiance
I think Pipiche will need more information.
Exactly what Hue light are you using. Because then the configuration can be modified.
Did you add it recently or some months ago? Because then you could try to update zigate plugin, remove the bulb light from domoticz and add it again to see if it is now already recognizd and created with the correct switch.
marktn
Post by marktn »
waltervl wrote: Monday 07 June 2021 20:56 I think Pipiche will need more information.
Hue white Ambiance GU10 5W
Model 9290019533
I did add them today
FirmwareVersion : 031d
PluginVersion : 4.12.107
domoticz 2021.1
i am already running a beta, should i update? I see there is a version 5 stable.
Please post here the export file of raw devices.
Zigate dashboard, menu tools, tools, raw devices json, export.
pipiche
Post by pipiche »
@marktn , please provide an export.json from the Tools -> Plugin Device List (RAW), this will help to do the changes and it will be posted on the beta at first.
marktn
Post by marktn »
pipiche wrote: Tuesday 08 June 2021 16:07 @marktn , please provide an export.json from the Tools -> Plugin Device List (RAW), this will help to do the changes and it will be posted on the beta at first.
I have made some exports, https://www.dropbox.com/sh/dim7nyvhhq1e ... NG28a?dl=0
"update 22:09" After restart sensors online. The Sirens seems not to charging, and only works on accu.
Very strange is, after adding the Hue lights some other devices went offline.
The Siren, TS0601-sirene is not working.
And mulit lumi sensors are offline.
pipiche
Post by pipiche »
Please go to Tools -> Plugin RAW Devices ( json) click on export and simply attach the file here, I do not understand what you have on the dropbox where there are several export.json
Thanks in advance
pipiche
Post by pipiche »
Screenshot 2021-06-08 at 22.15.15.png (38.34 KiB) Viewed 2130 times
please help me in just publishing what I need, I have no clue what is on your dropbox.
I simply need the export . You might have to add a .txt extension in order to upload here
marktn
Post by marktn »
pipiche wrote: Tuesday 08 June 2021 22:09 Please go to Tools -> Plugin RAW Devices ( json) click on export and simply attach the file here, I do not understand what you have on the dropbox where there are several export.json
Thanks in advance
Hi, thanks for support.
After restart domoticz, the sensors are online again.
Plugin RAW Devices.txt.txt
(310.61 KiB) Downloaded 135 times
pipiche
Post by pipiche »
is that : Hal - deur ?
marktn
Post by marktn »
pipiche wrote: Tuesday 08 June 2021 22:29 is that : Hal - deur ?
Yes! Hal-deur, Hal-lift, Hal-kast
pipiche
Post by pipiche »
please do update the plugin to beta-5.2.031. Then you will have to restart the plugin, remove the Widget and redo the pairing
marktn
Post by marktn »
pipiche wrote: Tuesday 08 June 2021 22:37 please do update the plugin to beta-5.2.031. Then you will have to restart the plugin, remove the Widget and redo the pairing
I done the update, but still the same. ColorControlRGBWW-0017880109796dad-0b/On)
pipiche
Post by pipiche »
Can you share the logs during the pairing , and if you can attach the export.json plugin devices Raw
marktn
Post by marktn »
pipiche wrote: Wednesday 09 June 2021 22:20 Can you share the logs during the pairing , and if you can attach the export.json plugin devices Raw
 2021-06-09 22:17:17.501 Status: New sensors allowed for 5 minutes...
2021-06-09 22:17:27.889 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Active Endpoint Response Ep: 0b LQI: 111
2021-06-09 22:17:27.889 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Active Endpoint Response Ep: f2 LQI: 111
2021-06-09 22:17:27.891 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Request Simple Descriptor for Ep: 0b
2021-06-09 22:17:27.892 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Request Simple Descriptor for Ep: f2
2021-06-09 22:17:27.783 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 8445 00178801097966b1 instead of None
2021-06-09 22:17:28.819 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Simple Descriptor Response EP: 0x0b LQI: 135
2021-06-09 22:17:28.819 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ProfileID 0104
2021-06-09 22:17:28.819 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ZDeviceID 010c
2021-06-09 22:17:28.819 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Application Version 0001
2021-06-09 22:17:28.819 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster IN Count: 09
2021-06-09 22:17:28.819 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 1: 0000 (Basic)
2021-06-09 22:17:28.819 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 2: 0003 (Identify)
2021-06-09 22:17:28.820 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 3: 0004 (Groups)
2021-06-09 22:17:28.820 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 4: 0005 (Scenes)
2021-06-09 22:17:28.820 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 5: 0006 (On/Off)
2021-06-09 22:17:28.820 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 6: 0008 (Level Control)
2021-06-09 22:17:28.820 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 7: 1000 (Touchlink)
2021-06-09 22:17:28.820 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 8: fc02
2021-06-09 22:17:28.821 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 9: 0300 (Colour Control)
2021-06-09 22:17:28.821 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster OUT Count: 01
2021-06-09 22:17:28.821 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-09 22:17:29.049 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Simple Descriptor Response EP: 0xf2 LQI: 135
2021-06-09 22:17:29.050 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ProfileID a1e0
2021-06-09 22:17:29.050 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ZDeviceID 0061
2021-06-09 22:17:29.050 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Application Version 0000
2021-06-09 22:17:29.050 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster IN Count: 00
2021-06-09 22:17:29.050 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster OUT Count: 01
2021-06-09 22:17:29.050 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster Out 1: 0021
2021-06-09 22:17:29.068 Status: Zigate: (Zigate) [0] NEW OBJECT: 8445 Request Node Descriptor
2021-06-09 22:17:29.069 Status: Zigate: (Zigate) [0] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-09 22:17:34.075 Status: Zigate: (Zigate) [1] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-09 22:17:37.256 EventSystem: Event triggered: Hal verlichting PIR en Sensor_1
2021-06-09 22:17:37.256 Error: EventSystem: Device no. '4945' used in event 'Hal verlichting PIR en Sensor_1' no longer exists, disabling event!
2021-06-09 22:17:39.067 Status: Zigate: (Zigate) [2] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-09 22:17:47.157 EventSystem: Event triggered: Buitenzit weer_1
2021-06-09 22:17:47.201 Dummy: Light/Switch (Buitenzit weer)
2021-06-09 22:17:47.157 Status: buitenzitweer ingeschakeld
2021-06-09 22:17:48.557 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4951/Zigate - ColorControlRGBWW-00178801097966b1-0b/Off)
2021-06-09 22:17:51.180 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4951/Zigate - ColorControlRGBWW-00178801097966b1-0b/On)
2021-06-09 22:17:58.751 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4951/Zigate - ColorControlRGBWW-00178801097966b1-0b/On)
2021-06-09 22:18:00.138 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4950/Zigate - ColorControlRGBWW-0017880109714b42-0b/On)
2021-06-09 22:18:00.574 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: dd5f Ieee: 0017880109714b42 MacCap: 8e
2021-06-09 22:18:00.809 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: Voordeur lamp NwkId: 73ea Ieee: 0017880108a2eb84 MacCap: 8e
2021-06-09 22:18:00.864 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: 8445 Ieee: 00178801097966b1 MacCap: 8e
2021-06-09 22:18:01.190 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4949/Zigate - ColorControlRGBWW-0017880109796dad-0b/On)
2021-06-09 22:18:01.337 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: 10e9 Ieee: 0017880109796dad MacCap: 8e
2021-06-09 22:18:02.375 Status: Notification sent (Email)
2021-06-09 22:18:02.647 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4949/Zigate - ColorControlRGBWW-0017880109796dad-0b/Off)
2021-06-09 22:18:03.992 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4950/Zigate - ColorControlRGBWW-0017880109714b42-0b/Off)
2021-06-09 22:18:05.039 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4951/Zigate - ColorControlRGBWW-00178801097966b1-0b/Off)
2021-06-09 22:18:12.815 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4949/Zigate - ColorControlRGBWW-0017880109796dad-0b/On)
2021-06-09 22:18:13.801 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4950/Zigate - ColorControlRGBWW-0017880109714b42-0b/On)
2021-06-09 22:18:14.873 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4951/Zigate - ColorControlRGBWW-00178801097966b1-0b/On)
2021-06-09 22:18:15.061 Error: dzVents: Error: (3.1.7) Discarding device. No last update info found: {["protected"]=false, ["timedOut"]=false, ["deviceType"]="Color Switch", ["lastUpdate"]="", ["batteryLevel"]=1823447856, ["subType"]="RGBWW", ["switchType"]="Dimmer", ["iconNumber"]=248, ["name"]="Zigate - ColorControlRGBWW-00178801097966b1-0b", ["changed"]=true, ["switchTypeValue"]=7, ["data"]={["hardwareType"]="Zigate plugin", ["usedByCamera"]=false, ["hardwareID"]=7908956, ["maxDimLevel"]=100, ["protected"]=false, ["_state"]="On", ["_nValue"]=1, ["color"]="", ["customImage"]=0, ["levelVal"]=0, ["unit"]=58, ["hardwareTypeValue"]=94, ["Image"]="Light", ["icon"]="dimmer", ["hardwareName"]="Zigate"}, ["id"]=4951, ["signalLevel"]=2686588, ["rawData"]={"On"}, ["description"]="", ["baseType"]="device", ["deviceID"]="", ["lastLevel"]=255, ["image"]=""}
2021-06-09 22:18:16.560 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4951/Zigate - ColorControlRGBWW-00178801097966b1-0b/Off)
2021-06-09 22:18:19.803 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4950/Zigate - ColorControlRGBWW-0017880109714b42-0b/Off)
2021-06-09 22:18:22.566 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4949/Zigate - ColorControlRGBWW-0017880109796dad-0b/Off)
2021-06-09 22:18:26.299 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4949/Zigate - ColorControlRGBWW-0017880109796dad-0b/On)
2021-06-09 22:18:26.980 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4950/Zigate - ColorControlRGBWW-0017880109714b42-0b/On)
2021-06-09 22:18:27.861 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4951/Zigate - ColorControlRGBWW-00178801097966b1-0b/On)
2021-06-09 22:18:30.368 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4941/Voordeur lamp (new)/On)
2021-06-09 22:18:32.902 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4941/Voordeur lamp (new)/Off)
2021-06-09 22:18:34.493 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (4941/Voordeur lamp (new)/On)
2021-06-09 22:18:37.600 EventSystem: Event triggered: Hal verlichting PIR en Sensor_1
export962021.txt
(291.11 KiB) Downloaded 107 times
pipiche
Post by pipiche »
can you kindly make a new try with the recent beta version ?
marktn
Post by marktn »
pipiche wrote: Thursday 10 June 2021 23:13 can you kindly make a new try with the recent beta version ?
Yes i did that. But still the same,
Zigate - ColorControlRGBWW-0017880109714b42-0b Color Switch RGBWW
export.txt
(285.2 KiB) Downloaded 75 times
pipiche
Post by pipiche »
Could you please enable the following debug and redo the pairing from scratch
DebugPairing
DebugCluster
DebugInput
And then provide the all log
marktn
Post by marktn »
pipiche wrote: Friday 11 June 2021 18:55 Could you please enable the following debug and redo the pairing from scratch
DebugPairing
DebugCluster
DebugInput
attached the log, do you need anymore logs?
logdomoticz.txt
(14.14 KiB) Downloaded 69 times
export04.txt
(281.94 KiB) Downloaded 104 times
marktn
Post by marktn »
I don't know if it is the same problem, maybe it can help for a solution.
2021-06-12 21:44:06.115 Error: Zigate: (Zigate) Decode8000 - PacketType: 0100 TypeSqn: 01 sqn_app: 7f sqn_aps: a5 Status: [E_ZCL_ERR_ZTRANSMIT_FAIL]
2021-06-12 22:04:06.107 Error: Zigate: (Zigate) Decode8000 - PacketType: 0100 TypeSqn: 01 sqn_app: 82 sqn_aps: 17 Status: [E_ZCL_ERR_ZTRANSMIT_FAIL]
