How to update an existing installation? Topic is solved
marmachine
Domoticz version: 3.4834
Post by marmachine »
When my Dashtics loads, it promts that an update (v3.9) is available.
This probably is a newbee question, although i'm getting an oldie...
Do i really need to create 'dev' dir and then run the command ". <(wget -qO - https://raw.githubusercontent.com/Dasht ... install.sh )"
My existing installation is in the default folder 'dashticz', so shouldn't i run the command in that folder instead of in the 'dev' folder?
It seems to me that the 'dev' folder brings me into trouble i guess... i'm getting the following result:
This is the installation script for Dashticz
Using default settings
Dashticz repository: https://github.com/Dashticz/dashticz
Branch: master
Port: 8082
The script will create a folder for Dashticz in the following location:
/home/pi/dev
Enter the folder name [dashticz]:
Dashticz will be installed in
dashticz
Dashticz has a master branch (=stable) and a beta branch (=most up-to-date)
Which branch to install? [master]:
Checking for git: [OK!]
Now cloning the Dashticz repository https://github.com/Dashticz/dashticz
Cloning into 'dashticz'...
remote: Enumerating objects: 2591, done.
remote: Counting objects: 100% (2591/2591), done.
remote: Compressing objects: 100% (1768/1768), done.
Receiving objects: 100% (2591/2591), 56.26 MiB | 3.46 MiB/s, done.
remote: Total 2591 (delta 1291), reused 1905 (delta 748), pack-reused 0
Resolving deltas: 100% (1291/1291), done.
^Cwarning: Clone succeeded, but checkout failed.
You can inspect what was checked out with 'git status'
and retry the checkout with 'git checkout -f HEAD'
the retry doesn't bring me any better result either...
fatal: not a git repository (or any of the parent directories): .git
heggink
Domoticz version: 12451
Re: How to update an existing installation?
Post by heggink »
just do a git pull in the installation folder and it will update.
P1 meter & solar panel
marmachine
Thx, that was helpfull indeed!
Daro1003
Domoticz version: 2023.1
Post by Daro1003 »
Hello
I go to the dashticz folder.
It does a git pull and this is what it shows me:
pi@smarticz:~ $ cd dashticz
pi@smarticz:~/dashticz $ git pull
Updating e5897d9b..6bac9acf
error: The following untracked working tree files would be overwritten by merge:
        lang/sl_SI.json
Please move or remove them before you merge.
Aborting
Lokonli
Post by Lokonli »
Probably you've changed that file.
Do you want to keep the changes or is it OK to throw the changes away?
Verstuurd vanaf mijn SM-A526B met Tapatalk
Daro1003
Post by Daro1003 »
I would not like what I have set in dashticz to change, but I also have a copy of the dashticz folder.
I want to update my dashtich
Lokonli
Post by Lokonli »
You made some changes to the translations in the file 'lang/sl_SI.json'
If you post your changes here, I can merge them in the next version of Dashticz.
If you've more translation updates, let me know, because then I'll give you access to the Dashticz project on lokalise.com, where the translations are managed.
To bring back the changed file to the original file:
git checkout lang/sl_SI.json
Then to get the latest Dashticz version:
git pull
Everything in the custom folder, including config settings, will be untouched.
Daro1003
Post by Daro1003 »
hmmm I never made any changes to the "lang/sl_SI.json" file, only what I set the language in the raspberry settings
sudo raspi-config
I do in the dashticz directory? Do domoticz?
W katalogu dashticz mam odpowiedz:
pi@smarticz:~/dashticz $ git checkout lang/sl_SI.json
error: pathspec 'lang/sl_SI.json' did not match any file(s) known to git
Daro1003
Post by Daro1003 »
pi@smarticz:~/dashticz $ sudo git checkout lang/sl_SI.json
Lokonli
Post by Lokonli »
ok, different way. Try the following:
In the Dashticz folder:
git reset --hard
git pull
Daro1003
Post by Daro1003 »
git reset --hard
error: unable to unlink old 'bin/glob-ls.js': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-brands-400.eot': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-brands-400.svg': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-brands-400.ttf': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-brands-400.woff': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-brands-400.woff2': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-regular-400.eot': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-regular-400.svg': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-regular-400.ttf': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-regular-400.woff': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-regular-400.woff2': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-solid-900.eot': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-solid-900.svg': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-solid-900.ttf': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-solid-900.woff': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/fa-solid-900.woff2': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/glyphicons-halflings-regular.eot': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/glyphicons-halflings-regular.svg': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/glyphicons-halflings-regular.ttf': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/glyphicons-halflings-regular.woff': Brak dostępu
error: unable to unlink old 'dist/assets/fonts/glyphicons-halflings-regular.woff2': Brak dostępu
error: unable to unlink old 'docs/troubleshooting/connection.rst': Brak dostępu
error: unable to unlink old 'docs/troubleshooting/docker.rst': Brak dostępu
error: unable to unlink old 'docs/troubleshooting/index.rst': Brak dostępu
error: unable to unlink old 'docs/troubleshooting/issues-domoticzblocks.rst': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/01d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/01n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/02d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/02n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/03d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/03n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/04d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/04n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/09d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/09n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/10d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/10n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/11d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/11n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/13d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/13n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/50d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/fill/50n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/01d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/01n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/02d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/02n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/03d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/03n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/04d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/04n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/09d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/09n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/10d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/10n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/11d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/11n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/13d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/13n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/50d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/line/50n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/01d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/01n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/02d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/02n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/03d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/03n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/04d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/04n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/09d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/09n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/10d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/10n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/11d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/11n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/13d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/13n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/50d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/linestatic/50n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/01d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/01n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/02d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/02n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/03d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/03n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/04d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/04n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/09d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/09n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/10d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/10n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/11d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/11n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/13d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/13n.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/50d.svg': Brak dostępu
error: unable to unlink old 'img/weathericons/meteo/50n.svg': Brak dostępu
error: unable to unlink old 'tpl/calendar_0.tpl': Brak dostępu
error: unable to unlink old 'tpl/calendar_1.tpl': Brak dostępu
error: unable to unlink old 'tpl/calendar_2_event.tpl': Brak dostępu
error: unable to unlink old 'tpl/calendar_2_modal.tpl': Brak dostępu
error: unable to unlink old 'tpl/calendar_2_template.tpl': Brak dostępu
error: unable to unlink old 'tpl/calendar_3.tpl': Brak dostępu
error: unable to unlink old 'tpl/calendar_4.tpl': Brak dostępu
error: unable to unlink old 'tpl/calendar_modal_iframe.tpl': Brak dostępu
error: unable to unlink old 'tpl/camera_image.tpl': Brak dostępu
error: unable to unlink old 'tpl/camera_video.tpl': Brak dostępu
error: unable to unlink old 'tpl/clock_hayman.tpl': Brak dostępu
error: unable to unlink old 'tpl/colorpicker.tpl': Brak dostępu
error: unable to unlink old 'tpl/corona_graph_header.tpl': Brak dostępu
error: unable to unlink old 'tpl/corona_report.tpl': Brak dostępu
error: unable to unlink old 'tpl/debug.tpl': Brak dostępu
error: unable to unlink old 'tpl/debugstatus.tpl': Brak dostępu
error: unable to unlink old 'tpl/dial.tpl': Brak dostępu
error: unable to unlink old 'tpl/dialblinds.tpl': Brak dostępu
error: unable to unlink old 'tpl/garbage_0.tpl': Brak dostępu
error: unable to unlink old 'tpl/garbage_1.tpl': Brak dostępu
error: unable to unlink old 'tpl/garbage_2.tpl': Brak dostępu
error: unable to unlink old 'tpl/graph_header.tpl': Brak dostępu
error: unable to unlink old 'tpl/graph_tooltip.tpl': Brak dostępu
error: unable to unlink old 'tpl/graph_tooltip_table.tpl': Brak dostępu
error: unable to unlink old 'tpl/news_modal.tpl': Brak dostępu
error: unable to unlink old 'tpl/news_row.tpl': Brak dostępu
error: unable to unlink old 'tpl/pubtrans_ov.tpl': Brak dostępu
error: unable to unlink old 'tpl/pubtrans_treinen.tpl': Brak dostępu
error: unable to unlink old 'tpl/secpanel.tpl': Brak dostępu
error: unable to unlink old 'tpl/secpanel_modal.tpl': Brak dostępu
error: unable to unlink old 'tpl/thermostat_block.tpl': Brak dostępu
error: unable to unlink old 'tpl/thermostat_evo_cont.tpl': Brak dostępu
error: unable to unlink old 'tpl/thermostat_evo_hw.tpl': Brak dostępu
error: unable to unlink old 'tpl/thermostat_evo_zone.tpl': Brak dostępu
error: unable to unlink old 'tpl/traffic.tpl': Brak dostępu
error: unable to unlink old 'tpl/tvguide_0.tpl': Brak dostępu
error: unable to unlink old 'tpl/tvguide_1.tpl': Brak dostępu
error: unable to unlink old 'tpl/weather_0.tpl': Brak dostępu
error: unable to unlink old 'tpl/weather_1.tpl': Brak dostępu
error: unable to unlink old 'tpl/weather_2.tpl': Brak dostępu
error: unable to unlink old 'tpl/weather_3.tpl': Brak dostępu
error: unable to unlink old 'tpl/weather_4.tpl': Brak dostępu
Checking out files: 100% (874/874), done.
fatal: Could not reset index file to revision 'HEAD'.
remote: Enumerating objects: 81, done.
remote: Counting objects: 100% (81/81), done.
remote: Compressing objects: 100% (32/32), done.
remote: Total 81 (delta 50), reused 77 (delta 49), pack-reused 0
error: insufficient permission for adding an object to repository database .git/objects
fatal: failed to write object
fatal: unpack-objects failed
The update is not going through for me.
It's also a strange thing because the domoticz roller blinds work correctly in all directions and the daschticz ones work the other way around
pi@smarticz:~/dashticz $ sudo git reset --hard
HEAD is now at e5897d9b Dial: Clean up
pi@smarticz:~/dashticz $ sudo git pull
Unpacking objects: 100% (81/81), done.
From https://github.com/Dashticz/dashticz
   9615c7b3..265d2743  beta       -> origin/beta
        lang/sl_SI.json
Aborting
[code]
Lokonli
Post by Lokonli »
Something is wrong with your .git folder, maybe some other things as well.
You have sufficient disk space?
I think ownership is incorrect: all files should be owned by pi.
Maybe it's most easy to make a backup of the custom folder in a save location, remove the dashticz folder, create a fresh install of Dashticz, and put back the files in the custom folder.
You can also try to fix it manually. In the Dashticz folder, something like:
sudo chown -R pi:pi .
chmod -R +rw .
git reset --hard
That should give no errors.
If you've still errors, you have to make a clean install.
Daro1003
Post by Daro1003 »
pi@smarticz:~/dashticz $ sudo chown -R pi:pi .
pi@smarticz:~/dashticz $ chmod -R +rw .
pi@smarticz:~/dashticz $ git reset --hard
        lang/sl_SI.json
Aborting
Lokonli
Post by Lokonli »
Almost ready :)
Remove the untracked file manually:
rm lang/sl_SI.json
and retry to update with:
git pull
Daro1003
Post by Daro1003 »
Thank you, the issue has already been resolved, I did a fresh install and everything works. Thank you for your help and involvement.
