I have some shutters (blinds) and I would like to change the value displayed cause it's in uppercase.
I tried the textOn/textOff but it's not working.
I tried the custom.js with function getStatus_MyBlind(block), and I can change the title (with block.title=), but how to change the value?
Thanks for your help
VM Debian - Domoticz stable v2025.2, RFXtrx433, Aeotec Z-Stick Gen5, Zigbee, Two APC
- rts: dio, oregon, somfy
- zwave: fibaro fgs212, aeotec smart switch, vision ZG8101
- IO Homecontrol: Velux Connexoon
- philips hue, Pilot app.
TroisSix wrote: Friday 05 March 2021 17:53
Hi huys,
It was hardcoded as ON and OFF (translated according your language setting).
I've just changed in latest beta that the textOn/textOff parameters can be used. Can you test?
Ok I will search a way to upgrade from the master to the beta, and come back to you, thanks
Edit: is that enough to upgrade from master to beta: (with a copy of the config js and co) ?
and is there a way to hide a block? cause I discovered that I need some buttons for the js and change the colors of other blocks, but I don't want to display these ones.
TroisSix wrote: Friday 05 March 2021 22:25
To be able to recover from mistakes, make a copy of CONFIG.js, custom.css and custom.js.
Then, normally the following should be sufficient to switch to beta:
@Lokonli
So I confirm the textOn/textOff is working fine with the latest beta: I can specify the text I want even for my blinds, great guys
Is there also a way to modify this state of another block within a function function getStatus_MyBlock(block)?
Dashticz.setBlock('AnotherBlind', {title: 'New title'}); is working to update the title of the blind, but what's the way to modify its data/value/state?
TroisSix wrote:@Lokonli
You could set the value parameter via the setBlock function.
Can you describe in more detail what you try to achieve?
