Colorpicker not shown Topic is solved
michelscholte
I have several Philips Hue White Ambiance lights (no color). In Domoticz I can control the colortemperature, but in Dashticz the colorpicker is not shown. I've added the colorpicker-setting to the generic settings and the block settings in the config.js file, but no result.
blocks['lamp eettafel'] = {
idx: 1116,
title: 'Lamp Eettafel',
last_update: false,
colorpicker: 2,
config['auto_positioning'] = 0;
config['colorpicker'] = 2;
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
idx: 1116,
last_update: false,
colorpicker: 2,
Lokonli
Re: Colorpicker not shown
Maybe it's not working with your device type yet (Philips Hue)
Can you post the Domoticz json device info:
(replace 123 with your Domoticz device id)
http://<domoticz ip:port>/json.htm?type=devices&rid=123-
Lokonli
and what is your exact Dashticz version?
If you open Dashticz in Chrome, press F12 to open DevTools, and refresh Dashticz:
Do you see any error in the DevTools console tab?
michelscholte
Lokonli,
I'm using version 3.6.6 (beta branch)
Below the Json device Info:
"ActTime" : 1604740178,
"AstrTwilightEnd" : "18:59",
"AstrTwilightStart" : "05:53",
"CivTwilightEnd" : "17:40",
"CivTwilightStart" : "07:12",
"DayLength" : "09:15",
"NautTwilightEnd" : "18:20",
"NautTwilightStart" : "06:32",
"ServerTime" : "2020-11-07 10:09:38",
"SunAtSouth" : "12:26",
"Sunrise" : "07:49",
"Sunset" : "17:04",
"app_version" : "2020.2 (build 12501)",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Color" : "{\"b\":0,\"cw\":70,\"g\":0,\"m\":2,\"r\":0,\"t\":185,\"ww\":185}",
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"DimmerType" : "abs",
"Favorite" : 0,
"HardwareID" : 8,
"HardwareName" : "Philips Hue",
"HardwareType" : "Philips Hue Bridge",
"HardwareTypeVal" : 38,
"HaveDimmer" : true,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "1",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2020-11-06 23:18:25",
"Level" : 51,
"LevelInt" : 51,
"MaxDimLevel" : 100,
"Name" : "Lamp Staand TV Hue",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" :
0
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "WW",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Color Switch",
"TypeImg" : "dimmer",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "1081"
"status" : "OK",
"title" : "Devices"
"Sunset" : "17:04",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 8,
"ID" : "1",
"Image" : "Light",
"Level" : 51,
"LevelInt" : 51,
"PlanID" : "0",
"PlanIDs" :
0
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "WW",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "1081"
"status" : "OK",
"title" : "Devices"
michelscholte
I only have 2 warnings:
bundle.js?t=6:345 The AudioContext was not allowed to start. It must be resumed (or created) after a user gesture on the page. https://goo.gl/7K7WLu
(anonymous) @ bundle.js?t=6:345
__webpack_require__ @ bundle.js?t=6:1
(anonymous) @ bundle.js?t=6:281
(anonymous) @ bundle.js?t=6:1
content.js:5 --------init----------- http://192.168.1.115:8082/
VM219:121 {AddjMulti: 1, AddjMulti2: 1, AddjValue: 0, AddjValue2: 0, BatteryLevel: 255, …}
VM219:121 {AddjMulti: 1, AddjMulti2: 1, AddjValue: 0, AddjValue2: 0, BatteryLevel: 255, …}AddjMulti: 1AddjMulti2: 1AddjValue: 0AddjValue2: 0BatteryLevel: 255CameraIdx: "2"CustomImage: 101Data: "On"Description: ""DimmerType: "none"Favorite: 0HardwareID: 1HardwareName: "Dummy"HardwareType: "Dummy (Does nothing, use for virtual switches only)"HardwareTypeVal: 15HaveDimmer: falseHaveGroupCmd: trueHaveTimeout: falseID: "72"Image: "Foscam"IsSubDevice: falseLastUpdate: "2020-11-02 20:33:53"Level: 0LevelInt: 0MaxDimLevel: 0Name: "Camera Havendijk 38"Notifications: "false"PlanID: "0"PlanIDs: [0]Protected: falseShowNotifications: trueSignalLevel: "-"Status: "On"StrParam1: ""StrParam2: ""SubType: "X10"SwitchType: "On/Off"SwitchTypeVal: 0Timers: "false"Type: "Lighting 1"TypeImg: "lightbulb"Unit: 10Used: 1UsedByCamera: trueXOffset: "0"YOffset: "0"idx: "2610"__proto__: Object
VM219:135 On
VM219:135 On
bundle.js?t=6:305 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send @ bundle.js?t=6:305
ajax @ bundle.js?t=6:305
handleStringBlock @ js/blocks.js:529
getBlock @ js/blocks.js:66
buildScreens @ js/main.js:676
onLoad @ js/main.js:398
(anonymous) @ js/main.js:293
mightThrow @ bundle.js?t=6:305
F @ bundle.js?t=6:305
setTimeout (async)
(anonymous) @ bundle.js?t=6:305
fire @ bundle.js?t=6:305
fireWith @ bundle.js?t=6:305
setTimeout (async)
setTimeout (async)
done @ bundle.js?t=6:305
load (async)
(anonymous) @ js/main.js:241
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
load (async)
(anonymous) @ js/main.js:217
setTimeout (async)
load (async)
(anonymous) @ js/main.js:210
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
load (async)
(anonymous) @ js/dashticz.js:81
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
Deferred.jQuery.each.Y.<computed> @ bundle.js?t=6:305
(anonymous) @ js/domoticz-api.js:101
setTimeout (async)
load (async)
jQuery.each.jQuery.<computed> @ bundle.js?t=6:305
newRequest @ js/domoticz-api.js:76
setTimeout (async)
add @ bundle.js?t=6:305
Deferred @ bundle.js?t=6:305
then @ bundle.js?t=6:305
domoticzRequest @ js/domoticz-api.js:53
requestSettings @ js/domoticz-api.js:440
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
load (async)
VM219:135 On
VM219:135 On
setTimeout (async)
setTimeout (async)
setTimeout (async)
load (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
load (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
load (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
load (async)
Lokonli
You can ignore the warnings.
I'll check your device type.
Lokonli
I've added support for dimmers with SubType 'WW' to latest beta.michelscholte wrote: Saturday 07 November 2020 10:18 Lokonli,
"Sunset" : "17:04",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 8,
"ID" : "1",
"Image" : "Light",
"Level" : 51,
"LevelInt" : 51,
"PlanID" : "0",
"PlanIDs" :
0
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "WW",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "1081"
"status" : "OK",
"title" : "Devices"
Can you test?
(I don't have Philips Hue WW lights, so I can't test myself)
michelscholte
It is working perfectly.
Thanks again.
Regards,
Michel
Thanks again.
Regards,
Michel
