Camera image rotate 90 degrees Topic is solved
gimic
Domoticz version: 3.66
Post by gimic »
Is it possible to rotate an image that comes from a camera 90 degrees?
i'ts declared in a button
buttons.ipcam1 = {key: 'cam1' , width:12, isimage:true, image: 'https://192.168.0.165/snap.jpg?JpegCam=1'}
Lokonli
Re: Camera image rotate 90 degrees
Post by Lokonli »
gimic wrote: Wednesday 22 May 2019 13:05 Is it possible to rotate an image that comes from a camera 90 degrees?
You can do that with a style-modifier in custom.css:
.buttons-cam1 img {
  transform: rotate(90deg);
gimic
Post by gimic »
Thanks, that does the trick!
