HomeWizard Wi-Fi P1 Extended
szelessavmuhely
I’ve created an extended version of the HomeWizard Wi-Fi P1 plugin for Domoticz and I’m looking for testers.
The goal of this plugin is to provide a more detailed and stable integration compared to the currently available version.
Main differences:
More detailed data (per phase voltage, current, power)
Better handling of import/export and tariffs
More consistent device structure in Domoticz
Multi-language support (all Domoticz languages)
Improved stability
GitHub:
https://github.com/szelessavalapitvany/ ... n-Extended
What I’m looking for:
General testing (installation, stability)
Feedback on device structure and values
Bug reports / edge cases
Suggestions for improvements
If you already use a HomeWizard P1 meter with Domoticz, your feedback would be especially valuable.
Thanks in advance!
Main differences:
Improved stability
GitHub:
Thanks in advance!
willemd
- Domoticz version: 2026.3
Re: HomeWizard Wi-Fi P1 Extended
I have all that already with http poller plugin.szelessavmuhely wrote: Tuesday 31 March 2026 5:39
Thanks in advance!
szelessavmuhely
Yes, this plugin focuses on providing a simple, ready-to-use solution with automatic setup.
manjh
- Domoticz version: 2025.2
I am using the original plugin, and found that the current usage value is a factor 10 too high, both the separate phase values, and also the Total.
Does this new plugin fix that?
Hans
manjh
I'm thinking to join your test program, but am unsure if I can install alongside with the current plugin.
Please advise.
Please advise.
Hans
manjh
Any thoughts?
If you want/need a tester community, it is important to be responsive!
Hans
Perhaps create an issue on his GitHub https://github.com/szelessavalapitvany/ ... ded/issues
It could be the forum.notifications are not sent or received.
manjh
Done, but no response sofar...waltervl wrote: Thursday 23 April 2026 22:13 Perhaps create an issue on his GitHub https://github.com/szelessavalapitvany/ ... ded/issues
Hans
manjh
OK, even though it remains very silent on your side, I decided to go ahead and install.
Dit it according to the instructions (manual install), restarted Domoticz. But I cannot see a new entry in the list of hardware devices.
Please help.
Please help.
Hans
szelessavmuhely
Sorry for the late reply. Notifications were enabled for this topic, but for some reason I didn't receive any notification about your post.
If the issue is still relevant, could you please check the Domoticz log immediately after restarting Domoticz and post any errors related to the plugin?
It would also be helpful to know:
* What device/platform are you running Domoticz on?
* Which Domoticz version are you using?
There is a 99% chance that the problem is related either to JSON API compatibility or to loading the `from distutils.version import LooseVersion` module.
The plugin was modified a few days ago to improve compatibility with Domoticz 2023.2 and newer versions.
If you post the startup log here, we should be able to identify the exact problem.
manjh
I must have done something wrong, but don't see what.
Installed the plugin according to the instructions, and restarted Domoticz.
But then, on the hardware page, I can see two entries for the HomeWizard plugin, and neither shows the word "Extended".
I can see the HomeWIzard Wifi P1 meter, and the HomeWizard Electric P1 meter.
Am I missing something?
Hans
pfloryann
It is very likely that the plugin is installed twice. Access the `domoticz/plugins` directory via FTP and check, or use the console—run the command `cd domoticz/plugins/` followed by `dir`—and verify if the plugin folder appears twice.manjh wrote: Wednesday 30 September 2026 14:38 I must have done something wrong, but don't see what.
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
manjh
Twice... I think I misinformed you.
When I click the dropdown and look for HomeWizard, I can see two choices:
Which of the two is your plugin?
When I installed the plugin, I first removed the old installation.
This is what I see now in the plugin directory:
HomeWizard Wifi P1 meter
HomeWizard-Wifi-p1-plugin
HomeWizard-Wifi-p1-plugin-Extended
Hans
manjh
OK, got it. For some reason I expected a different name.
I've used the Electric version, but now see errors:
Should I worry, or will this fix over time after the first startup?
Also, will I be able to run both P1 plugins at the same time? Some of my scripts still work with the old devices, and I donot want to change anything for now.
2026-10-01 17:04:24.592 Status: HW P1E: Entering work loop.
2026-10-01 17:04:24.592 Status: HW P1E: Started.
2026-10-01 17:04:24.816 Status: HW P1E: Initialized version 1.0.0, author 'szelessavmuhely.hu'
2026-10-01 17:04:25.191 Status: Warning: Expecting svalue with at least 5 elements separated by semicolon, 1 elements received ("0"), notification not sent (Hardware: 31 - HW P1E, ID: 001F002F, Unit: 47, Type: FA - P1 Smart Meter, SubType: 1 - Energy)
2026-10-01 17:05:24.111 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:05:24.115 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:05:24.125 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:05:24.133 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:05:24.134 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:05:24.139 Error: Invalid Number sValue: '%' for device idx: '%'
Hans
manjh
It doesn't fix over time. When I look at the timestamp, it looks like there are three error messages at each run.
2026-10-01 17:06:24.085 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:06:24.091 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:06:24.095 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:07:24.112 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:07:24.116 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:07:24.120 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:08:24.109 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:08:24.112 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:08:24.117 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:09:24.109 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:09:24.114 Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:09:24.118 Error: Invalid Number sValue: '%' for device idx: '%'
Hans
szelessavmuhely
Hello!
My colleagues and I will look into it tomorrow...
Please help by describing your setup: what device and which version of Domoticz are you using?
Best regards,
Attila
Best regards,
Attila
szelessavmuhely
We have fixed an issue in the plugin code related to the initialization of device 47. In theory, this issue should only have caused problems until the first successful data update.
Please update the plugin code from GitHub and restart Domoticz. Then delete the existing plugin instance from the Hardware menu and create it again using the same settings.
Please let us know whether this resolves the problem.
Thank you for your cooperation!
