Python Plugin: GoodWe solar inverter via SEMS API
RNEE
Domoticz version: 2026.1
Re: Python Plugin: GoodWe solar inverter via SEMS API
Post by RNEE »
@jan-jaap : update runs now ! Thank you !
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek Homebattery 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|
Jeweettoch13
Domoticz version: 2026.2
Post by Jeweettoch13 »
Awesome Work Jan-jaap!
It seems though that the data is coming trough is not what Domoticz expect it to be:
I've reset the value but am not sure if im missing 3 days of generated power. Ill investigate further.
Jeweettoch13
Also:
1 of 2 MPP-trackers is going to zero occasionally but they are working both as well in domoticz. Current output value is also none.
RNEE
Post by RNEE »
I have the same problem in my dzVents script.
i think Goodwe now delivers sometimes nil- values, so domoticz calculaties te difference.
i think we need an otter variable witch always holds the cummelative total values.
Regarding time-out errors : the token has a live of 60 minuten, so it does not have to be renewed every time. Goodwe says renew every 50 minuts.
Jeweettoch13
Fair enough :).
In the fixed script no output current comes with the data. Could this be addressed?
