Python PLugin : Lyrion Music Server
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
I've made a Plugin for the Lyrion Music Server, formaly known as Logitsch Media Server
The buildin plugin still works, but is a bit limited
There are not mpw devices and functionalities added.
I've tested the plugin and it is working, but of course the can always be some issues.
The plugin is not tested with multiple devices
Please share you findings
You can find the plugin over here : https://github.com/MadPatrick/domoticz_Lyrion
Domoticz version: 2025.1
Re: Python PLugin : Lyrion Music Server
Thanks, so the current Logitech media server integration is not working anymore? https://wiki.domoticz.com/Logitech_Media_Server
madpatrick
waltervl wrote: Saturday 15 November 2025 20:18 Thanks, so the current Logitech media server integration is not working anymore? https://wiki.domoticz.com/Logitech_Media_Server
Still working, but limited
Also it gives sometimes an error in the JSON.
See the raised issue on Domoticz GIT
capman
Post by capman »
I have this error in the log: Error: Lyrion Music Server: Unable to load icon pack 'LMS.zip'
In the plugin it's named lyrion.zip , so I renamed it to LMS.zip , but no luck.
madpatrick
You need also correct the names inside the zip./
I've corrected it and uploaded the correct LMS.zip
Also a new version with a small fix
capman
Post by capman »
madpatrick wrote: Friday 27 February 2026 14:42 Hi,
Working now , thanks :D
