There should be a detailed log on the api response for the lock status? If you send that to me, I can see if I can find the problem.
Python Plugin: Toyota Topic is solved
- Domoticz version: 2020.2
Re: Python Plugin: Toyota
Hmmmm. when I click the"Logs" page, the app shows the message "Connecting to log stream..." and the freezes. I cannot move to another page anymore. Closing the browser helps, I can the access the main page again.
Hans
Depending on your server you night have to wait 10 seconds or so until it connects to the log stream. I haven't had the time up optimize that part. You could also run the server outside the docker, then you get the logs in the terminal.
I think this may be an error in the Toyota part, when I unlock the car the original Toyota app also shows all doors as "locked". And I am 100% sure they are unlocked. So I guess this is not an error in the plugin!
Hans
