Python Plugin: OpenAQ Topic is solved
- FireWizard
Re: Python Plugin: OpenAQ
@Jan Jansen
You are probably right, as I found that I'm using an older version, which updates every hour and not every minute.
Looked into the source, but except of that line I cannot find anything that indicates the update frequency.
So @Xorfor has to answer this question.
@Jan Jansen
Xorfor
Fortunately openaq.org allows unlimited requests in their API
Because of a big change in Oct 2019 in the plugin, the self.__MINUTES was not used anymore. I have updated the plugin and implemented this again and now the plugin will update the sensors only once per hour.
Jan Jansen
- Domoticz version: Stable
@ Xorfor,
Thanks for your time and attention, it works as desired!
Jan
Jan
- FireWizard
@Xorfor,
I have installed the new version and I can confirm that it works as intended.
rrozema
It has been doing this since yesterday. It's probably them having an issue, not a problem of the plugin.(Air quality) openaq returned a status: 504
- FireWizard
I think, it is an incident, as I saw it only once in the log:
From: https://developer.mozilla.org/en-US/doc ... Status/5042020-11-23 21:29:33.373 Error: (Air Quality) openaq returned a status: 504
RegardsThe HyperText Transfer Protocol (HTTP) 504 Gateway Timeout server error response code indicates that the server, while acting as a gateway or proxy, did not get a response in time from the upstream server that it needed in order to complete the request.
rrozema
I agree that it is probably an incident at their side, and as such it will probably go away once they discover there's a problem in their server(s). However, it is happening every +- 5 minutes in my log, so that's why I wanted to share this to let others know it is not just themFireWizard wrote: Tuesday 24 November 2020 14:59 Hi,
- Domoticz version: 2026.3
Seems that Xorfor was so nice to update the plugin yesterday to the new OpenAq V2 Api. I just tried and it seems to work. I get measurements but have to wait 1 hour to see if they update....
So in the plugin folder of OpenAQ do a git pull and it should work again after an update of the OpenAQ Hardware in Domoticz.
Derik
- Domoticz version: BETA
Hi... looks the plugin is gone on git..
Only after a new setup in domoticz is in my db the plugin "working"...
And i cannot remove the plugin because he is not there..
Some a solution?
Some a solution?
I am currently updating this plugin as it now needs an API key to get the data. It is testing at the moment. I will report back when it is working properly...
It is running now for some hours, everything seems to be OK.
So the modified fork is here:
https://github.com/waltervl/Domoticz-OpenAQ-Plugin
To update from the old plugin
1. Edit the config file in the .git folder of the plugin and change the url from Xorfor into waltervl
2. Do a "git pull" in the plugin folder to update the plugin.
3. Register on OpenAQ and get your API KEY from https://explore.openaq.org/account.
4. Restart Domoticz
5. Go to menu Setup - Hardware, select the plugin hardware gateway and add the API KEY to the OpenAQ plugin configuration.
6. Click on Update. Now the plugin will start and succeeds to login and update the existing devices.
Alternative for step 1 and 2 is to go to the github repository, copy the contents of the plugin.py and paste it into the plugin.py of your Domoticz server and so overwiting is contents.
url = https://github.com/waltervl/Domoticz-OpenAQ-Plugin.git3. Register on OpenAQ and get your API KEY from https://explore.openaq.org/account.
4. Restart Domoticz
- JayDotR
Hi Waltervl,
As the plugin was working well until october 2024, I read that the old API calls in V1 and V2 would be decomissionned in a near future (it happens that they redesigned the API). I permitted myself to fork your plugin and redesign it a little bit in order to make it V3 API compliant. For the moment, it's stable.
If you would like to test it, feel free. If it's stable for you, I am fine with a link on the Domoticz Plugins Site
Nevertheless, without the work of Xofor and yourself, I would have taken far more time.
https://github.com/janreimen/Domoticz-OpenAQ-Plugin
Domoticz Beta on raspberry3b, and raspberry4(b) on Rasbian Trixie / Python 3.13 / 64 bit
Using: PiHole, SolarEdge Modbus, Sainlogic / Weather Underground, MQTT, Fritzbox, P1 Meter(s), dzvents Scripting
https://www.github.com/janreimen/
