Python Plugin: SAJ Modbus Plugin Topic is solved
CloudAlchemyIO
For anyone interested in a SAJ solar power inverter plugin, I have created a plugin for this inverter.
It uses the Elfin EE11A Modbus TCP server for connecting to it. It is still a work in progress, and all comments are very welcome.
It is developed with and tested on:
- Domoticz version: 2021.1 (Ubuntu 21.04 and Raspbian GNU/Linux 10 (buster))
- Zonneplan ONE/SAJ Solar Inverter R5-4K-S2
- Elfin-EE11A (RS485 to Ethernet)
https://github.com/CloudAlchemyIO/domoticz-saj-plugin
Maybe someone else finds it useful as well.
- Domoticz version: 2026.3
Re: Python Plugin: SAJ Modbus Plugin
Why are you using custom sensors for Energy? And why so many (today, month, year etc).
You can use just Energy (Instant and counter) device Python 243 type 29 and you have current, today, week, month, year in one device!
https://www.domoticz.com/wiki/Dummy_for ... counter.29
Also custom sensors do not store their history so you cannot see more than one year back.
CloudAlchemyIO
Okay, thank you for your comments, I will definitely check on those, it's my first plugin.
I didn't know that custom sensors do not store their history for long.
Thanks again.
Thanks again.
At least you are trying so that is good!
For the working hours you can use a Counter, custom values. You just have to send the total counter and Domoticz will do the today calculation for you.
Also this device has History logging. Python device 243 type 33 ID 3 (counter). I think there is only the problem that you cannot set the Unit of measure (eg hours) with the Python plugin framework for this device.
https://www.domoticz.com/wiki/Dummy_for ... es#Counter
pizzulicchio
Hi,CloudAlchemyIO wrote: Tuesday 14 September 2021 13:42 For anyone interested in a SAJ solar power inverter plugin, I have created a plugin for this inverter.
where is possible to download again your plugin?
I'd like to test with my SAJ Inverter model HS2-5K-S2-X with wifi connection that use modbus protocol.
let me know.
thank you
It seems non available anymore.
I found a dzvents script that perhaps works for you
https://www.domoticz.com/forum/viewtopic.php?t=30953
pizzulicchio
I have got a saj HS2-5K-S2-X inverter with eSolar AIO3 module (wifi/ethernet/bluetooth )
This module or this inverter, doesn't support a status page in xml or a web login. All datas are sended to esolar portal cloud using mqtt or some other way..
I have seen that AIO3 module is a modbus adpater (502 tcp port is open ) but i don't know how to extract production datas.
That dzevents script is not working with my saj inverter series.
You can try if this gives data: https://github.com/wimb0/saj_modbus
Install python module pymodbus==2.3.0 eg
sudo pip3 install pymodbus==2.3.0Domoticz running on Udoo X86 (on Ubuntu)
pizzulicchio
Thank you very much for your suggestion.
I'm testing this plugin and it works partially.
only the invertor details, no real time data... i will try to reboot the AIO3 module.
- SajModbus.JPG (40.47 KiB) Viewed 5493 times
