Error executing script command returned: 256 Topic is solved
JanvdW
Re: Error executing script command returned: 256
Post by JanvdW »
In that case I don't understand why your script is executed in the background, because there's no ampersand in the script?
JanvdW wrote: Friday 05 February 2021 9:54 In that case I don't understand why your script is executed in the background, because there's no ampersand in the script?
Because the script does not use the Lua functions os.execute or io.popen but a separate (and async) thread coded in the domoticz program called by the dzVents function dz.executeShellCommand()
JanvdW
Post by JanvdW »
Thanks; the script works fine. I'll have a look at my other Blockly's to optimize the system
JanvdW
Post by JanvdW »
As discussed I am changing my scripts to async versions, but I am struggling with one of my scripts. It's a script that checks presence of family members based on ip connection of their mobiles phone:
return { on = { timer  = { "every 5 minutes" } },
    logging = {  level  = domoticz.LOG_INFO, marker = "Ping smartphones" },
    data = { timeoutcount = { initial = {} } },
    execute = function(dz, device)
        local devices_ping =  { ['Smartphone 1']    = 'xx.xx.xx.xx',
                                ['Smartphone 2']    = 'xx.xx.xx.xx',
                                ['Smartphone 3']    = 'xx.xx.xx.xx',
                                ['Smartphone 4']    = 'xx.xx.xx.xx',
                                ['Smartphone 5']    = 'xx.xx.xx.xx'}
        local timeout       = 3                                                			-- # timeouts, before a switch off will be executed
        local timeoutcount  = dz.data.timeoutcount                              -- short reference
        for deviceName, ipaddr in pairs(devices_ping) do
            ping_success=""
            ping_success=os.execute('ping -c1 -w1 ' .. ipaddr)
            if timeoutcount[deviceName] == nil then
                    timeoutcount[deviceName] = 0
            if ping_success then
                if timeoutcount[deviceName] == 0 then
                    print("ping "..deviceName.." success ")
                    if timeoutcount[deviceName] >= timeout then                 -- log wordt alleen weggeschreven als device offline is geweest
                        print("ping "..deviceName.." success, device is back.")
                    timeoutcount[deviceName] = 0                                	-- reset the counter
                if dz.devices(deviceName).state == 'Off' then
                    dz.devices(deviceName).switchOn()
            elseif timeoutcount[deviceName] < timeout then
                timeoutcount[deviceName] = timeoutcount[deviceName] + 1
                print("ping ".. deviceName .." ".. timeoutcount[deviceName] .." times failed.")
                --print ("ping ".. deviceName .." has " ..timeoutcount[deviceName].. " timeouts, this exceeds the timeout number setting.")
                if dz.devices(deviceName).state == 'On' then
                    dz.devices(deviceName).switchOff()
I added an ampersand to the os.execute command as follows:
ping_success=os.execute('"ping -c1 -w1 " .. ipaddr &')
. It seems to work (no errors), but results always in positive values, even when devices are not connected. Is something wrong with the syntax?
JanvdW wrote: Monday 22 February 2021 22:48 As discussed I am changing my scripts to async versions, but I am struggling with one of my scripts. It's a script that checks presence of family members based on ip connection of their mobiles phone:
Not directly with the syntax but the os.execute does not return the resultcode of the ping command but it returns the result of the &, meaning that it returns the result of sending the command to the background which always succeeds.
This behavior was one of the main reasons to develop the executeShellCommand() in dzVents (available in dzVents >= 3.1.0 / build >= 12771) which is true async and returns its result via trigger shellCommandResponses
JanvdW
Post by JanvdW »
That explains what happens; thanks for your explanation. I had a look already at executeShellCommand() already, but it was not clear to me how to use it in a loop, where the executeShellCommand() is called for multiple (in my case 5) devices.
JanvdW wrote: Tuesday 23 February 2021 8:23 That explains what happens; thanks for your explanation. I had a look already at executeShellCommand() already, but it was not clear to me how to use it in a loop, where the executeShellCommand() is called for multiple (in my case 5) devices.
In this case I would leave the looping to the ShellCommand. Below small bash script will do it for you and nicely shows the result in a JSON that can be processed further in dzVents when it is returned by the shellCommandResponse
bash script
#! /bin/bash
# bash script to loop over all parms and ping them. Parms should be a valid IPv4 or IPv6 address or hostname
# call like  ./myPing.sh dz 192.168.192.1 192.168.192.199 8.8.8.8 noHost ::1 home.synology.me
# output will look like
# {"dz":0,"192.168.192.1":0,"192.168.192.199":1,"8.8.8.8":0,"noHost":2,"::1":0,"home.synology.me":0,}
myJSON='{'
# Loop over all parms
for ((i=1; i<=$#; i++))
do
  ping -q -c1 -w1 ${!i}  > /dev/null 2>&1
  myJSON=$myJSON\"${!i}\":$?, # add ip + result to the JSON
done
echo ${myJSON::-1}"}" # remove last , and add }
dzVents part
local scriptVar = 'shell pinger'
return
    on =
        timer =
            'every minute',
        shellCommandResponses =
            scriptVar,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    execute = function(dz, item)
        if item.isTimer then
            local IPTable =
                "dz",
                "192.168.192.1",
                "192.168.192.199",
                "8.8.8.8",
                "noHost",
                "::1",
                "home.synology.me",
                command = '/home/pi/domoticz/scripts/myPinger.sh ' .. table.concat(IPTable,' '),
                callback = scriptVar,
                timeout = #IPTable -- same number of seconds as there are entries in IPTable
        elseif item.isShellCommandResponse and item.json then
            rt = item.json
            for host, rc in pairs(rt) do
                dz.log('Ping result of "' .. host .. '" : ' .. rc, dz.LOG_DEBUG)
            dz.log('There was a problem handling the command', dz.LOG_ERROR)
            dz.log(item, dz.LOG_DEBUG)
JanvdW
Post by JanvdW »
That's a good idea to solve this.
I implemented this but have some errors:
  • strange enough I get the following error message:
    Error: dzVents script command running longer than specified timeout(5 seconds), cancelling...
  • At other moments I get log entries like
    2021-02-23 14:20:05.736 Error: dzVents: Error: (3.1.5) shell pinger: Error parsing json to LUA table: /home/pi/domoticz/scripts/dzVents/../lua/JSON.lua:808: trailing garbage at byte 231 of: {"xx.xx.xx.xx":0,"xx.xx.xx.xx":0,"xx.xx.xx.xx":0,"xx.xx.xx.xx":1,"xx.xx.xx.xx":1}
    2021-02-23 14:20:05.736 {"xx.xx.xx.xx":0,"xx.xx.xx.xx":0,"xx.xx.xx.xx":0,"xx.xx.xx.xx":1,"xx.xx.xx.xx":1,"xx.xx.xx.xx":0,"xx.xx.xx.xx":0,"xx.xx.xx.xx":0,"xx.xx.xx.xx":1,"xx.xx.xx.xx":1,}
    2021-02-23 14:20:05.736 Error: dzVents: Error: (3.1.5) shell pinger: There was a problem handling the command
    2021-02-23 14:20:12.657 Error: dzVents script command running longer than specified timeout(5 seconds), cancelling..
erem
Domoticz version: 2021.1
Post by erem »
@JanvdW
check your line endings in the script.
I'll bet the trailing garbage is cr-lf from a cut-paste from a windows editor.
Regards,
Rob
JanvdW
Post by JanvdW »
Found the issue; it appears that the bash script was corrupted.
I have one question left. Based on the timer the script starts at 20:45:00.726 and finished at 20:45:00.826. Then the ShellCommandResponse starts the script at 20:45:05.035 and finished at 20:45:05.062
I don't understand why I get an error message that timeout of 12 seconds is exceeded:
Error: dzVents script command running longer than specified timeout(12 seconds), cancelling...
. A message that I get over and over again.
JanvdW wrote: Tuesday 23 February 2021 16:47 I don't understand why I get an error message that timeout of 12 seconds is exceeded:
What is your build?
The errormessage could be the bug that was introduced in build 12970 and fixed in build 12974
If you are on build >= 12974 and still see the message then try and change line
timeout = ( #IPTable + 10 ) -- same number of seconds as there are entries in IPTable + 10
JanvdW
Post by JanvdW »
Great; thanks. The system was on build 12972. After upgrade (to 12983) the error message is gone.
