Python Plugin : Xiaomi Philips LED Ball Lamp Topic is solved
deennoo
Hello There
I'm starting a new plugin, for some Xiaomi Philips Wifi Device.
All main work come from Kofec and his plugin for Xiaomi Air Purifier : https://github.com/kofec/domoticz-AirPurifier
I just spend some time to adapt it for the E27 Bulb aka Xiaomi Philips LED Ball Lamp aka Philips ZhiRui E27 bulb.
That a first version, With 3 Widgets
ON/OFF
Brightness
White Temp
You Can drive the Bulb directly from Domoticz and from MiHome APP (set refresh to 1 minute to have best update)
Know Issue :
- Restarting the plugin create a segmention Fault, you need to restart your domoticz
- Plugin doesn't know if your bulb are Online or not
Next evolutions are :
Using Native Domoticz CCCW Widget
Using set_brightness_and_color_temperature(brightness, cct) command avaiable on Python-miio
You can Grab it : https://github.com/deennoo/domoticz-Xia ... ree/master
ON/OFF
Brightness
White Temp
Know Issue :
http://domo-attitude.fr
deennoo
Re: Python Plugin : Xiaomi Philips LED Ball Lamp
v0.1.1 is out
Adding ability to use 4 Scenes already present In the Bulb
deennoo
switching to beta branch allow you to use cccw widget
https://github.com/deennoo/domoticz-Xia ... /MyBulb.py
just missing now :
on/off from this widget
refresh this widget from bulb status
using native python-miio module to by pass MyBulb.py
just missing now :
arek156
- Domoticz version: 3.8153
Hello
Great script, just how to generate a token?
N1co
I cannot get this to work.
I checked the miio2.db on my android phone but the token of the light bulb is empty.
vuko
@N1co, it's not a place for this info but here's how it worked on my devices:
If you have android phone, install older version of MiHome - 5.0.19 for example from appkmirror. Then follow the guide from there for non-rooted android: https://github.com/jghaanstra/com.xiaom ... n_token.md
(newer versions of android MiHome, doesn't store device tokens)
tontze
- Domoticz version: Beta Ch
Just bought few of these bulbs, works very nice with android app. Havent tried this plugin yet, as i understood its not ready yet. Waiting to try it out when its ready
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
fecus
- Domoticz version: 4.11597
Thank you your efforts!
It is almost working.
In the CCCW widget the color is not variable. Only the dimmer work.
And, can I define new scene? If yes, how?
N1co
Thanks. In the end I used the packet sender method to get the token. Plugin works great now!vuko wrote: Monday 24 December 2018 0:27 @N1co, it's not a place for this info but here's how it worked on my devices:
qwerk
Hi, I bought two of these lamps and I am trying to use them using this plugin.
I keep getting this error:
2019-01-04 16:59:06.981 Error: (XiaomiPhilipsLEDBallLamp) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/xiaomi_led_bulb/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2019-01-04 16:59:06.981 Error: (xiaomi lamp 02) Module Import failed, exception: 'ImportError'
2019-01-04 16:59:06.981 Error: (xiaomi lamp 02) Module Import failed: ' Name: typing'
2019-01-04 16:59:06.981 Error: (xiaomi lamp 02) Error Line details not available.
I tried to update python3 that did not help. now running 3.7.2
I am missing something, but I dont know what.
can you advice where to look?
izmirkubiak
- Target OS: -
Have you been able to advance on integration xiaomi philips? Because I just acquired the spot zhirui and I am very happy, remains to integrate correctly.
Thank you for all the work already done, and in advance for the future.
Samael
- Domoticz version: 4.9701
Hi!
I managed to get this plugin working under Windows. I am ready to help in finalizing the plugin to a full state. deennoo, could you add me to the Collaborators?
PS: Windows Server 2012R2 Essentials, Python 3.6.8
2019-01-17 00:57:41.928 Status: (test5) Started.
2019-01-17 00:57:42.309 (test5) 'Author':'Deennoo'
2019-01-17 00:57:42.309 (test5) 'Name':'test5'
2019-01-17 00:57:42.309 (test5) 'Address':'192.168.10.102'
2019-01-17 00:57:42.309 (test5) 'Port':'0'
2019-01-17 00:57:42.309 (test5) 'Key':'XiaomiPhilipsLEDBallLamp'
2019-01-17 00:57:42.309 (test5) 'Mode1':'89bedfa9123841a44030fd4ae2a0db09'
2019-01-17 00:57:42.309 (test5) 'Mode3':'1'
2019-01-17 00:57:42.309 (test5) 'Mode6':'Debug'
2019-01-17 00:57:42.310 (test5) 'DomoticzVersion':'4.9701'
2019-01-17 00:57:42.310 (test5) 'DomoticzHash':'98723b7d'
2019-01-17 00:57:42.310 (test5) 'DomoticzBuildTime':'2018-06-28 09:00:58'
2019-01-17 00:57:42.310 (test5) Device count: 2
2019-01-17 00:57:42.310 (test5) Device: 1 - ID: 45, Name: 'PhLamp - Scenes', nValue: 1, sValue: '40'
2019-01-17 00:57:42.310 (test5) Device ID: '45'
2019-01-17 00:57:42.310 (test5) Device Name: 'PhLamp - Scenes'
2019-01-17 00:57:42.310 (test5) Device nValue: 1
2019-01-17 00:57:42.310 (test5) Device sValue: '40'
2019-01-17 00:57:42.310 (test5) Device LastLevel: 40
2019-01-17 00:57:42.310 (test5) Device: 2 - ID: 46, Name: 'PhLamp - CCCW', nValue: 1, sValue: '10'
2019-01-17 00:57:42.310 (test5) Device ID: '46'
2019-01-17 00:57:42.310 (test5) Device Name: 'PhLamp - CCCW'
2019-01-17 00:57:42.310 (test5) Device sValue: '10'
2019-01-17 00:57:42.310 (test5) Device LastLevel: 10
2019-01-17 00:57:42.310 (test5) Pushing 'PollIntervalDirective' on to queue
2019-01-17 00:57:42.311 (test5) Device UNIT_SCENES with id 1 exist
2019-01-17 00:57:42.311 (test5) Device UNIT_CCCW with id 2 exist
2019-01-17 00:57:42.311 (test5) onHeartbeat called
2019-01-17 00:57:42.307 Status: (test5) Entering work loop.
2019-01-17 00:57:42.308 Status: (test5) Initialized version 0.1.2, author 'Deennoo'
2019-01-17 00:57:43.088 (test5) <PhilipsBulbStatus power=on, b .... ne=4, delay_off_countdown=0>
2019-01-17 00:57:43.088 (test5) power => on
2019-01-17 00:57:43.088 (test5) brightness => 10
2019-01-17 00:57:43.088 (test5) color_temperature => 1
2019-01-17 00:57:43.088 (test5) scene => 4
2019-01-17 00:57:43.088 (test5) delay_off_countdown => 0>
2019-01-17 00:57:43.088 (test5) Starting device update
2019-01-17 00:57:43.089 (test5) onHeartbeat finished
2019-01-17 00:57:43.089 (test5) Processing 'PollIntervalDirective' message
2019-01-17 00:57:43.089 (test5) Heartbeat interval set to: 20.
2019-01-17 00:57:51.831 (test5) Pushing 'onHeartbeatCallback' on to queue
2019-01-17 00:57:51.872 (test5) Processing 'onHeartbeatCallback' message
2019-01-17 00:57:51.872 (test5) Calling message handler 'onHeartbeat'.
2019-01-17 00:57:51.872 (test5) onHeartbeat called
2019-01-17 00:57:51.872 (test5) Awaiting next pool: 2019-01-17 00:58:42.311525
2019-01-17 00:57:53.737 (test5) Pushing 'onCommandCallback' on to queue
2019-01-17 00:57:53.759 (test5) Processing 'onCommandCallback' message
2019-01-17 00:57:53.759 (test5) Calling message handler 'onCommand'.
2019-01-17 00:57:53.759 (test5) onCommand called for Unit 2: Parameter 'Off', Level: '10', Color:
2019-01-17 00:57:53.759 (test5) settings: 192.168.10.102 89bedfa9123841a44030fd4ae2a0db09
2019-01-17 00:57:53.759 (test5) Call command: ['python', './MyBulb.py', '192.168.10.102', '89bedfa9123841a44030fd4ae2a0db09', '--power', 'OFF']
2019-01-17 00:57:54.720 (test5) <PhilipsBulbStatus power=off, brightness=10, color_temperature=1, scene=4, delay_off_countdown=0>
2019-01-17 00:57:54.720 (test5) onHeartbeat called
2019-01-17 00:58:00.229 (test5) <PhilipsBulbStatus power=off, .... ne=4, delay_off_countdown=0>
2019-01-17 00:58:00.229 (test5) power => off
2019-01-17 00:58:00.229 (test5) brightness => 10
2019-01-17 00:58:00.229 (test5) color_temperature => 1
2019-01-17 00:58:00.229 (test5) scene => 4
2019-01-17 00:58:00.229 (test5) delay_off_countdown => 0>
2019-01-17 00:58:00.246 (test5) Update 0:'10' (PhLamp - CCCW)
2019-01-17 00:58:00.264 (test5) Update 0:'40' (PhLamp - Scenes)
2019-01-17 00:58:00.264 (test5) Starting device update
2019-01-17 00:58:00.264 (test5) onHeartbeat finished
2019-01-17 00:58:11.851 (test5) Pushing 'onHeartbeatCallback' on to queue
2019-01-17 00:58:11.864 (test5) Processing 'onHeartbeatCallback' message
2019-01-17 00:58:11.864 (test5) Calling message handler 'onHeartbeat'.
2019-01-17 00:58:11.864 (test5) onHeartbeat called-
yezzer
- Domoticz version: V4.10363
Hello Nicolas,
Many thanks for this great work to integrate the Xiaomi Zhirui Led E27 ball bulb into Domoticz!
I was looking for thist feature about more than a year!
I also want to thank you in advance for all the excellent work you have done, and will do in future to improve the script.
about the integration in my version of domoticz (bèta V4.10363 with python 3.5.3):
I only get two tabs, namely the tab with the predefined 4 scènes and the tab with CCCW
the other tabs are missing...
furthermore, I wonder if the newest Xiaomi Aqara ZNLDP12LM LED Smart Bulb (zigbee) can also be implemented in future?
deennoo
has i don't plan to buy this spot, sorry i can't help, but maybe you can check if Python lib that i use already have something for you and then you can adapt my plugin :izmirkubiak wrote: Monday 14 January 2019 16:31 Hello,
https://python-miio.readthedocs.io/en/l ... ilips_bulb
deennoo
Done,Samael wrote: Wednesday 16 January 2019 21:39 Hi!
Feel free to add some stability on this plugin !
deennoo
Other tab was created for beta, but removed because not needed as i manage to create and use a cccw widgetyezzer wrote: Wednesday 23 January 2019 20:31
Samael
Hi folks!
I fixed some bugs and added support for Windows to the plugin.
You can test it here: https://github.com/deennoo/domoticz-Xia ... ee/win-fix
deennoo
I've just merge it, good jobSamael wrote: Saturday 26 January 2019 15:09 Hi folks!
mgabor
Dear All,
I have tried to install the Xiaomi Philips bulb and it was almost successful, but the Domoticz does not recognize the bulb. Int error status I hav found this: 2019-02-01 18:07:32.235 Error: (Light1) Call command failed: Command '['bash', '-c', './MyBulb.py', 'here the IP, I deleted it', 'here the token, I deleted it', '--power', 'OFF']' returned non-zero exit status 2
What can I do?
I have found this error in Python:
=== RESTART: /home/pi/domoticz/plugins/domoticz-Xiaomi-Led-Lamp/MyBulb.py ===
usage: MyBulb.py [-h]
[--level {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99}]
[--temp {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99}]
[--power {ON,OFF}] [--debug] [--scene {1,2,3,4}]
[--brightemp BRIGHTEMP]
IPaddress token
MyBulb.py: error: the following arguments are required: IPaddress, token
Where is the problem?
What can I do?
IPaddress token
mgabor
Dear Deennoo,deennoo wrote: Tuesday 13 November 2018 22:50 Hello There
ON/OFF
Brightness
White Temp
Know Issue :
What can I do?
IPaddress token
