Python Plugin: PiMonitor
Xorfor
Post by Xorfor »
A small plugin available for the Raspberry Pi:
https://github.com/Xorfor/Domoticz-PiMonitor-Plugin
To monitor CPU speed, usage, temperature, etc.
Xorfor
Re: Python Plugin: PiMonitor
Post by Xorfor »
Added extra devices, like memory, up time, number of network connections, etc.
emme
Domoticz version: latest
Post by emme »
just a question.....
what's the difference between this plugin and the Motherboard sensors hardware?
"We always done this way"
Xorfor
Post by Xorfor »
I wrote this plugin to monitor the RPi on which I develop other plugins. I want to see eg. the cpu speed, number of connections, which is not possible with the Motherboard sensors hardware. So, this plugin shows some more information.
A disadvantage of this plugin, that it works on a RPi and probably also other Linux devices (not tested). Not on Windows!
That is also the reason that I wrote the Disc usage plugin (https://github.com/Xorfor/Domoticz-Disc-usage-Plugin). The standard Motherboard sensors only displays some directories. With the Disc usage plugin, I am able to also monitor mounted disks.
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Besides that, Hardware monitor Memory Usage looks at the amount Domoticz uses or the calculation is different.
While the plugin looks for the total amount of memory used.
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
Velly
Post by Velly »
Hi<
following LOG errors:
2018-01-27 18:11:48.970 Error: (PiMonitor) 'onStart' failed 'KeyError'.
2018-01-27 18:11:48.970 Error: (PiMonitor) ----> Line 162 in /home/pi/domoticz/plugins/PiMonitor/plugin.py, function onStart
2018-01-27 18:11:48.970 Error: (PiMonitor) ----> Line 56 in /home/pi/domoticz/plugins/PiMonitor/plugin.py, function onStart
What could be wrong with?
Xorfor
Post by Xorfor »
@Velly,
Did you also placed the xfr_pimonitor.zip in the plugin directory? This contains the images of the plugin, and it seems that the plugin has problems to get these images.
Velly
Post by Velly »
yes, pictures are fine
htilburgs
Post by htilburgs »
I was wondering if it is possible to monitor a 'remote' pi?
In mine situation I've 2 Raspberrys.
  • RPi 2B (DHCP, DNS, VPN, MQTT, HomeBridge)
  • RPi 3 (Domoticz)
While running Domoticz on the RPi3 I'm able to monitor this one with the PiMonitor Plugin.
What I like to do is monitor the other (RPi2B) also with the PiMonitor Plugin. Is this possible?
Hardware:
emme
Post by emme »
thanks for clarify....
It looks a good script! (like I am a linux guru!! :lol: :lol: :lol: :lol: )
I'm testing it
Al33Rob
Domoticz version: 3.8914
Post by Al33Rob »
Thanks for developing this script, i am trying to use and have the basic setup installed, ie i can create the hardware and the devices are created as well however in the log i'm seeing the below messages. Can you advise if i'm missing something.
2018-01-31 20:50:32.568 (RasPi_Info) Calling message handler 'onHeartbeat'.
2018-01-31 20:50:32.569 (RasPi_Info) onHeartbeat called
2018-01-31 20:50:32.569 (RasPi_Info) CPU count...: 1
2018-01-31 20:50:32.605 (RasPi_Info) CPU temp....: 37.4 °C
2018-01-31 20:50:32.605 Error: (CDevice_update) RasPi_Info - CPU temperature: Failed to parse parameters: 'nValue', 'sValue', 'SignalLevel', 'BatteryLevel' or 'Options' expected.
2018-01-31 20:50:32.605 Error: (RasPi_Info) 'CDevice_update' failed 'TypeError':''TimedOut' is an invalid keyword argument for this function'.
2018-01-31 20:50:32.606 (RasPi_Info) Update RasPi_Info - CPU temperature: 37 - '37.4'
2018-01-31 20:50:32.647 (RasPi_Info) GPU temp....: 36.9 °C
2018-01-31 20:50:32.648 Error: (CDevice_update) RasPi_Info - GPU temperature: Failed to parse parameters: 'nValue', 'sValue', 'SignalLevel', 'BatteryLevel' or 'Options' expected.
2018-01-31 20:50:32.648 Error: (RasPi_Info) 'CDevice_update' failed 'TypeError':''TimedOut' is an invalid keyword argument for this function'.
2018-01-31 20:50:32.648 (RasPi_Info) Update RasPi_Info - GPU temperature: 36 - '36.9'
2018-01-31 20:50:32.684 (RasPi_Info) GPU memory..: 64.0 Mb
2018-01-31 20:50:32.684 Error: (RasPi_Info) 'onHeartbeat' failed 'AttributeError':''Domoticz.Device' object has no attribute 'TimedOut''.
2018-01-31 20:50:32.685 Error: (RasPi_Info) ----> Line 190 in /home/pi/domoticz/plugins/pimonitor/plugin.py, function onHeartbeat
2018-01-31 20:50:32.685 Error: (RasPi_Info) ----> Line 115 in /home/pi/domoticz/plugins/pimonitor/plugin.py, function onHeartbeat
2018-01-31 20:50:32.685 Error: (RasPi_Info) ----> Line 216 in /home/pi/domoticz/plugins/pimonitor/plugin.py, function UpdateDevice
Xorfor
Post by Xorfor »
@htilburgs: No is not possible
@Al33Rob: Please use the latest Domoticz beta! Your version is too old for this (and probably other) plugin.
Al33Rob
Post by Al33Rob »
@Xorfor Thanks this sorted it!
Velly
Post by Velly »
sometimes there is huge difference between Monit memory data and PiMonitor data:
like on screens
Any reason/solution? Thank you!
memory pi monit.JPG (46.97 KiB) Viewed 13631 times
pimonitor memory.JPG (105.02 KiB) Viewed 13631 times
Xorfor
Post by Xorfor »
@Velly,
On internet you will find a lot of different ways to calculate the memory usage. The all give different values. The plugin is using an algorithm based on 'free' eg. as can be found on https://gist.github.com/funvill/5252169.
I have no idea how Monit is calculating the memory usage.
EddyG
Post by EddyG »
I use both RPi-Monitor https://github.com/XavierBerger/RPi-Monitor as Monit https://mmonit.com/monit/
Both do an excellent job outside of Domoticz.
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Velly wrote: Saturday 27 January 2018 16:15 Hi<
Xorfor wrote: Saturday 27 January 2018 17:34 Did you also placed the xfr_pimonitor.zip in the plugin directory? This contains the images of the plugin, and it seems that the plugin has problems to get these images.
Hi Xorfor, I have the same errors as Velly. The xfr_pimonitor.zip is in the same directory as the plugin.py Do I have to unpack the xfr_pimonitor.zip? Is the name of the plugin-dicetory important?
Greetings McMelloW
Xorfor
Post by Xorfor »
@McMelloW,
You don't need to unpack the zipfile. Last week I had another RPi with the same problem.
I found out that there was a problem updating the database. The image files were created in the www/images folder, but in Setup -> More options -> Custom Icons, the image did not appear. I don't have this problem at this moment with V3.8914!!!
I suggest:
1. to upgrade to the latest beta,
2. in Hardware, delete PiMonitor
3. Add PiMonitor again.
Velly
Post by Velly »
@xorfor
I tried:
Result:
I get NO devices anymore (tried to reboot etc etc)
I am getting same errors in log, but this time I am unable to see new PiMonitor devices in list..
Needed to restore from IMG file - or I had no chances at all to see PiMonitor devices in my list..
actual working (with errors) setup: 3.8820 beta, pi3 Jessie, python 3.4
Xorfor
Post by Xorfor »
@velly,
Hummm, my RPi is running on v3.8914. Yours seems older, not the latest beta. As far as I remember that was also the version I got this problem.
Try:
cd domoticz
./updatebeta
Then you are on the latest beta. Try the steps 2-3 again.
If still no devices available, check in Setup -> More options -> Custom icons. Do you see the pimonitor icons? If not try to upload the zip file.
If zip file succesfully uploaded, try step 2-3 again.
