Reading values from database Topic is solved
I have a couple of counters for my power- and gas-usage. These are devices of a dummy-hardware, and I fill the values using calls to the JSON-URL from an Arduino that reads my P1-port (RPi is not located in the meter cupboard).
When I view the log I get these nice graphs, and I can download the inidivdual values that make the graph up as CSV or something else.
Now is my question: is it possible to read these individual values from the database? So I'm not talking about the last value, but a range of them (e.g. all values of today).
I'll be using it in a cron, so bash or python would work the best, but PHP is also a possibility. My problem is accessing the database through a script.
Suggestions?
Suggestions?
Re: Reading values from database
It's a Sqlite database, so there are plenty of examples on the net for Perl, Python to access it.
Okay, I have worked with PHP, but never with Perl or Python before. I'll try to gather something together!SweetPants wrote: ↑Friday 18 August 2017 21:24 It's a Sqlite database, so there are plenty of examples on the net for Perl, Python to access it.
If you google for "Php Sqlite" there is plenty of information available to access the database with Php http://php.net/manual/en/book.sqlite.php
- Egregius
- Domoticz version: v2024.7
Use php to read the sqlite database. Once you have the data in a array you can do whatever you want with it.
Maybe even better for the future: let php store the raw data in a mysql database, at least that's what I do for some thermometers.
Okay, thanks SweetPants and Egregius!
2 more questions though: Where do I put the PHP-file? I tried putting it in /home/pi/domoticz/www and requesting it through the browser (192.168.0.35:8080/test.php), but all I got was a "Domoticz Offline"-page (without the test.php appended it responds normally).
Second question: I seem to need the nme of the database to connect to it. Is that simply "domoticz.db", like the file I can download through the backup-button?
- Egregius
You'll need a PHP enabled webserver like apache, lighttpd, nginx,...
Will post some code tomorrow as example.
Okay, I'll wait for your reply then, thanks for the effort!
I was under the impression that PHP could be used as standard within the www-folder of Domoticz, don't know where I got that idea though...
- Egregius
I have these PHP packages installed on my RPi:
You need at least php7.0-sqlite3 to enable reading from a SQL lite 3 database and the user that runs the script (or the user that runs the webserver) needs full read/write/execute permissions to the folder and file where the domoticz.db database is stored.
Then, to select some stuff (adjust the path to database, mine is stored in tmpfs):
php7.0 php7.0-cgi php7.0-common php7.0-fpm php7.0-json php7.0-mysql php7.0-phpdbg php7.0-sqlite3 php-apcu php-common
php7.0-bcmath php7.0-cli php7.0-curl php7.0-gmp php7.0-mbstring php7.0-opcache php7.0-readline php7.0-xml php-cgi
<?php
$db=new SQLite3('/var/log/domoticz.db');
$results=$db->query('SELECT Temperature, Date FROM Temperature WHERE DeviceRowID = 442');
while($row=$results->fetchArray()){
print_r($row);
echo '<br>';
Thanks a million! I have my domoticz.db in /home/pi/domoticz/domoticz.db, not in /var/log, but I got enough info here to get it working I think!Egregius wrote: ↑Saturday 19 August 2017 7:00 I have these PHP packages installed on my RPi:You need at least php7.0-sqlite3 to enable reading from a SQL lite 3 database and the user that runs the script (or the user that runs the webserver) needs full read/write/execute permissions to the folder and file where the domoticz.db database is stored.Code: Select all
php7.0 php7.0-cgi php7.0-common php7.0-fpm php7.0-json php7.0-mysql php7.0-phpdbg php7.0-sqlite3 php-apcu php-common php7.0-bcmath php7.0-cli php7.0-curl php7.0-gmp php7.0-mbstring php7.0-opcache php7.0-readline php7.0-xml php-cgi
Then, to select some stuff (adjust the path to database, mine is stored in tmpfs):Code: Select all
<?php $db=new SQLite3('/var/log/domoticz.db'); $results=$db->query('SELECT Temperature, Date FROM Temperature WHERE DeviceRowID = 442'); while($row=$results->fetchArray()){ print_r($row); echo '<br>'; }
