Export of IDX to long Topic is solved
All kinds of 'OS' scripts
PieterS
Domoticz version: 2024.7
Post by PieterS »
Try to upload a counter of the gassensor from Domoticz to Mindergas.nl.
This is the script:
#!/bin/bash
#Token to authenicate with mindergas.nl
TOKEN=**************************
#fetch meterstand (use jq to parse JSON object correctly)
METERSTAND=`curl -s "http://127.0.0.1:8084/json.htm?type=devices&rid=734"  | jq '.result[0].Counter'| tr -d '"'`
#Get OS date, and format it corectly.
NOW=$(date +"%Y-%m-%d")
#Build JSON by hand ;-)
JSON='{ "date":"'$NOW'", "reading":"'$METERSTAND'"  }'
#post using curl to API
curl -v -H "Content-Type:application/json" -H "AUTH-TOKEN:$TOKEN" -d "$JSON" https://www.mindergas.nl/api/gas_meter_readings
The problem is in the line to extract the Counter of the gassensor with Idx 734in Domoticz:
The result is: 693.927m3 So it ends with the text m3 and that is the point!
How do I cut those last two characters out of the variable? I just need the value!
Thanks for your hint!
Synology with Domoticz build (V2024.7) in Docker
Re: Export of IDX to long
PieterS wrote: Friday 25 January 2019 23:57 Try to upload a counter of the gassensor from Domoticz to Mindergas.nl.
693.927m3 So it ends with the text m3 ; How do I cut those last two characters out of the variable? I just need the value!
Try this
#!/bin/bash
METERSTAND=${METERSTAND::-2}
PieterS
Post by PieterS »
THANKS A LOT! You made my day! Upload succeeded.
I noticed a chance in the output of the call to fetch all data that belongs to a device as described in the text on the WIKI: https://www.domoticz.com/wiki/Mindergas.nl
There it says:
The script is explained as:
So if you only do on the cli of your pi you can find out what the actual JSON object is. Just do this:
curl -s "http://127.0.0.1:8080/json.htm?type=devices&rid=8"
It turns out that the object looks like this:
  "5MinuteHistoryDays" : 7,
  "ActTime" : 1414866673,
  "AllowWidgetOrdering" : true,
  "DashboardType" : 0,
  "Latitude" : "52.135674",
  "Longitude" : "6.182462",
  "MobileType" : 0,
  "TempScale" : 1.0,
  "TempSign" : "C",
  "WindScale" : 1.0,
  "WindSign" : "m/s",
  "dontcachehtml" : true,
  "result" : [
        "BatteryLevel" : 255,
        "Counter" : "128.865",
        "CounterToday" : "1.865 m3",
Probably the output changed in the last stable version: I use Domoticz V4.9700 on a Synology with DSM 6.2. Or the sensor is a bit different..
Anyway: Thanks a lot for your hint! It means word[-2:] # characters from the second-last (included) to the end :D
