I have only one event. Event is eneabled in Domoticz.
In log show this:
2016-06-17 11:14:42.410 OpenZWave: Domoticz has send a Switch command! NodeID: 7 (0x07)
2016-06-17 11:14:42.427 EventSystem: Event triggered: test_1
2016-06-17 11:14:42.411 (Z-Wave) Light/Switch (Ośw. pompa)
2016-06-17 11:45:15.903 User: admin initiated a switch command
2016-06-17 11:45:15.904 OpenZWave: Domoticz has send a Switch command! NodeID: 7 (0x07)
2016-06-17 11:45:15.930 EventSystem: Event triggered: test_2
2016-06-17 11:45:15.905 (Z-Wave) Light/Switch (Ośw. pompa)
But when i change type vistual switch to ON/OFF and correct in event status for "test" it works ok. Can you test on your system Domoticz ?
I need create script to combinate two device with two other UNIT to one device status in Domoticz...
I use ELMES Switch Contact connected to RFLink and it has two UNIT. I need connect it to one device in domoticz by scripting.
Status OPEN has UNIT 4 but status CLOSED has UNIT 12.
