All new blockly functions are available now (including math) except:
controls_repeat_ext — repeat N times
controls_whileUntil — repeat while / until
controls_flow_stat — break out of loop
logic_loop — (v13's new loop block)
this is because -according to my AI- Domoticz events are condition → action and compile to flat Lua statements; there's no loop construct in the generated event logic
v13 API renames handled (e.g. math_pow → math_pow10)
Regression-tested: existing events parse to identical Lua as before
How to test:
git clone https://github.com/hyeronimo/domoticz.git
cd domoticz && git checkout blockly-value-blocks
make && sudo make install # or your usual build flow
What to check: create a new Blockly event with a condition using Math/Text/Lists blocks, save it, and verify the generated Lua in the event file; also open an existing event and confirm it still loads and runs.
