I want to switch on the light for one minute using a PIR but only after sunset and before sunrise. How can I acconplish that?
Sunrise and Sunset Topic is solved
- Treve
- Domoticz version: v4.11474
Re: Sunrise and Sunset
It’s quite simple to do with a blockly.ChrisVH1982 wrote:Hello,
- make a variable ‘nighttime’
- make a blockly
“if time is sunset” “set Nighttime =on” and “if time is sunrise” “set Nightime =off”
If Pir is on and Nighttime is on set light=on for 1 minute
That’s all.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Domoticz version: 12467
If [Time > Sunset] or [Time < Sunrise] and [Light = Off] and [PIR = On]
Set [Light = On for [1] minutes.
I used a dummy switch instead of a variable as Treve wrote. This Dummy switch was switched by timer. But this is not necessary for what you want to accomplish now.
- Treve
As far i know there are Time complications with calculations before 00:00 and after 00:00.AllesVanZelf wrote:If [Time > Sunset] or [Time < Sunrise] and [Light = Off] and [PIR = On]
That’s the reason I made use of a variable.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
The complication you refer to is: If [Time > Sunset] and [Time < Sunrise]
That will never happen. That is why I used OR.
Then it is working.
Then it is working.
- Treve
Produce this solution every minute a ‘on’ signal?AllesVanZelf wrote:If [Time > Sunset] or [Time < Sunrise] and [Light = Off] and [PIR = On]
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
