buienradar lua script
jvdz
Domoticz version: 4.107
Re: buienradar lua script
Post by jvdz »
I have no idea what those 2 values exactly do as I am using my own LUA scripts for both the Rain prediction (posted somewhere in this thread) and a separate script for the weather predictions, where I filter out the information I need and put that in Domoticz for processing.
This is running for a couple of years already, when this integrated hardware wasn't there yet.
I have separate scripts as they point to different Buienradar websites and the rain prediction runs every 5 minutes and the weather forecast runs every 10 minutes.
Jos
Joske
Post by Joske »
okay, i will take a look.
I thought it should be simple, but the wind-sensor gives an output like: 225.00;SW;79;114;15.2;15.2
So i guess the windage (in this example it was 11.4 m/s) is given as : 114.
So its not very simple i guess : )
But always nice to learn, the rain LUA word perfectly!
What i do see:
You can go to 'notifications' on the sensor. there its possible to get an notification (for example en e-mail) when the windage is above X m/s.
Thats a start :)
What i shall try:
Als 'notification' type i choose: HTTP
And the als HTTP i give the command for the screen; hopefully it works :)
Will test it now
EDIT:
Via http it doesn't work within the notification setting.
I see i am not the only one : (https://www.domoticz.com/forum/viewtopic.php?t=6828 )
On a rainy day with lots of time i will try to test other options, if anyone has an working 'windage' script thats always welcome :roll:
jvdz
Post by jvdz »
Joske wrote: Monday 29 June 2020 11:44 okay, i will take a look.
I gave the formula already for that a few posts ago! ;)
jvdz wrote: Monday 29 June 2020 10:03 As you can see, there is also a Wind sensor there and you can use that data to retrieve the windspeed and windgustspeed :
sDirectionDegrees, sDirection, sSpeed, sGust, sTemperature, sFeel = otherdevices_svalues['Wind']:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
So you can very simply test on either the variable sSpeed or sGust depending which value you find important.
Something like this to get you started?:
-- only check windspeed when Wind info is updated
if devicechanged['Wind'] then
	-- check whether the sunscreen is "out"
	if (otherdevices['Sunscreen'] == 'Open') then
		-- send warning when speed is over 60km
		if sSpeed < 60 then
			print('Windsnelheid hoger dan 60 km en Sunscreen is open.')
Jos
Joske
Post by Joske »
:roll: :oops:
Oepsie...thanks!
I will try to make it work !
Joske
Post by Joske »
Managed by doing this: https://www.domoticz.com/forum/viewtopic.php?t=28163
A blockly with:
IF > WIND > 10 AND Sunscreen = Open
Do: Close Sunscreen
Now looking for the best setting; i don't know if it takes the peak ('windvlaag') or the everage windspeed (snelheid in m/s)
Edit:
It looks like its taking the peaks, thats fine.
There are peaks with 15m/sec here wright now, and when i play with the parameters i can see the screens doesn't even goes out because of the wind.
Perfect :D
Jimster
Post by Jimster »
Anybody else having issues with the LUA script recently?
Seems like the output from buienradar has changed.
077|17:15
077|17:20
86,6329598612474|17:25
86,6329598612474|17:30
077|17:35
077|17:40
86,6329598612474|17:45
86,6329598612474|17:50
92,2678801510292|17:55
99,3670401387526|18:00
112,64618727381878|18:05
112,64618727381878|18:10
105,8988795837422|18:15
111,53379987352399|18:20
112,64618727381878|18:25
105,8988795837422|18:30
118,6329598612474|18:35
123,30905700295102|18:40
129,590485647558|18:45
131,3670401387526|18:50
131,3670401387526|18:55
118,6329598612474|19:00
112,64618727381878|19:05
105,8988795837422|19:10
jvdz
Post by jvdz »
yep... I changed my version to this to t=get the rain and time variables filled now :
while true do
   line = file:read("*line")
   if not line then break end
   rain,linetime = line:match("(%d+).-|(.+)%s?")
   rain = tonumber(rain) or 0
   linetime = linetime or "00:00"
   linetime = linetime:gsub("[\r\n]","")
   if debug then print('Rain in timerange: '..rain .. '   linetime:'..linetime..'    Line:' ..line ) end
Jos
Jimster
Post by Jimster »
jvdz wrote: Friday 02 October 2020 18:05 yep... I changed my version to this to t=get the rain and time variables filled now :
while true do
Jos
Hi Jos,
Thanks for your help. I'm not experienced in scripting, so I have no clue where to change this. Can you post your full script and if possible in Dutch?
jvdz
Post by jvdz »
Just Email me your script and I will have a look as it could very well be you are using a totally different version.
My email address can be found in my github account details.
Jos
ps: .. and in Dutch is fine too. ;)
Jimster
Post by Jimster »
Thanks to @jvdz it's working again.
Change this line in the script from
for k,v in tmp:gmatch('(.-)|(.-)\r?\n') do
to
for k,v in tmp:gmatch('(%d+).-|(.-)\r?\n') do
Thanks Jos!
jvdz
Post by jvdz »
You're welcome. It actually simply takes the numeric part up to the comma and skips the rest as they change the values for rain|time from:
123|10:00
to
123,456789|10:00
.. but we really do not need the part behind the comma (which is use in the Netherlands as Decimal sign).
The other option would to replace the comma for a decimal point in the string value before converting to a number.
Jos
Joske
Post by Joske »
nf999 wrote: Saturday 31 March 2018 21:26
So incidentally this script will go over 10secs. If you don't want this adjust the nr of repetitions to 2, or reduce the timeout to 3 secs in os.capture. This setup was fine for me.
This worked fine for the error, thanks!!
HansieNL
Post by HansieNL »
jvdz wrote: Saturday 03 October 2020 17:08 The other option would to replace the comma for a decimal point in the string value before converting to a number.
Can you help me to change my lua script so it will work with the decimal point? Thanks in advance.
-- script_time_buienradar.lua
-- BuienRadar Module
-- curl in os required!!
-- create dummy text device from dummy hardware 'Buien Radar'
-- create dummy rain sensor from dummy hardware 'BuienRadarMeter'
-- create dummy switch from dummy hardware for triggering screens etc based on rain
-- add as time based lua script
-- set your longitude & latitude below!
-- 2017-12-27 working version
-- 2017-12-28 trying to get the rain device working .. missing documentation ..
-- 2017-12-30 isolated the bug, i was overwriting the updatedevice .. should be ok now
-- 2018-03-28 updated buienradar url
-- 2018-04-02 added follow redirect for curl & fixed typo as tipped by gizmocuz
local myBuienRadarDevice = 'Buienradar'
local myBuienRadarMeter = 'RegenData'
local myBuienRadarFlg = 'Paraplu'
-- longitude latitude
local lat='51.00'
local lon='3.00'
time = os.date("*t")
if time.min % 5 == 0 then
    print('(Buienradar) Get data from Buienradar')
    function os.capture(cmd, rep)   -- execute command to get site
        -- rep is nr of repeats if result is empty
        r = rep or 1
        local s = ""
        while ( s == "" and r > 0) do
            r = r-1
            local f = assert(io.popen(cmd, 'r'))
            s = assert(f:read('*a'))
            f:close()
        if ( rep - r > 1 ) then
            print("(Buienradar) os.capture needed more than 1 call: " .. rep-r)
      return s
    --  get data from buienradar
    -- local command = "curl --max-time 3 -L -s 'https://gpsgadget.buienradar.nl/data/raintext?lat=" .. lat .. "&lon=" .. lon .. "'"  -- timeout 3 secs
    local command = "curl --max-time 3 -L -s 'https://gps.buienradar.nl/getrr.php?lat=" .. lat .. "&lon=" .. lon .. "'"  -- timeout 3 secs
    -- print("command: " .. command)
    local tmp = os.capture(command, 3)  -- nr of repetitions 3
    -- print('buienRadar data:\n' .. tmp)
    if ( tmp == "" ) then
        print("(BuienRadar) Empty result from curl command")
        -- analyse data
        -- to mm/h 10^((waarde-109)/32)
        function tomm(r)
            return 10^((r-109)/32)
        -- to string formatted
        function tos(r, c)
            c = c or 1
            return string.format("%." .. c .. "f", r)
        local c=0
        local rainNow=0
        local rainNowAvg = 0
        local rainSoon = 0
        local rainTime = ""
        local rainMax = 0
        for k,v in tmp:gmatch('(.-)|(.-)\r?\n') do  -- k is rain value, v is time
            kn = tonumber(k)
            if c<=1 then
                if rainNow < kn then
                    rainNow = kn
                if kn > 0 then
                    rainNowAvg = rainNowAvg + tomm(kn)/2
            if c<=3 and rainSoon < kn then
                rainSoon = kn
            if rainTime == "" and kn > 0 then
                rainTime = v
            if kn > rainMax then
                rainMax = kn
            c = c+1
        -- if c = 0 no data found!
        if ( c == 0 ) then
            print("(BuienRadar) Unparsable result from curl command")
            if rainNow>0 then
                tmp = "Nu " .. tos(tomm(rainNow)) .. " mm/uur"
                if rainMax > rainNow then
                    tmp = tmp .. " tot " .. tos(tomm(rainMax)) .. " mm/uur"
            elseif rainSoon>0 then
                tmp = "Verwacht " .. tos(tomm(rainSoon)) .. " mm/uur"
                if rainMax > rainSoon then
            elseif rainTime ~= "" then
                tmp = "Verwacht om " .. rainTime .. " tot " .. tos(tomm(rainMax)) .. " mm/uur"
            else tmp = "Voorlopig droog"
            -- calculate totalrainfall using rainNowAvg as average of 2 next reports
            -- print("buienRadarMeterOld: " .. otherdevices_svalues[myBuienRadarMeter])
            local rainTot = tonumber(otherdevices_svalues[myBuienRadarMeter]:match("[^;]+;([^;]+)")) + rainNowAvg/12 -- /12 to acount for 5min measurements ?? ..
            -- print("buienRadarDebug: rainNow=" .. tos(tomm(rainNow)) .. " rainNowAvg=" .. tos(rainNowAvg) .. " rainSoon=" ..
            --      tos(tomm(rainSoon)) .. " rainTot=" .. tos(rainTot,2) .. " rainTime=" .. rainTime .. " rainMax=" .. tos(tomm(rainMax)))
            local cmd = otherdevices_idx[myBuienRadarMeter] .. "|0|" .. tos(tomm(rainNow)*100,0) .. ";" .. tos(rainTot,2)
            -- print("buienRadar: " .. cmd)
            table.insert(commandArray, { ['UpdateDevice'] = cmd } ) -- table.insert needed to avoid overwriting with next updatedevice
            -- write to text device
            if otherdevices[myBuienRadarDevice] ~= tmp then
                table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[myBuienRadarDevice] .. '|0|' .. tmp })
                -- trigger based when rainNow or rainSoon
                if ( rainNow>0 or rainSoon>0 ) then
                    if otherdevices[myBuienRadarFlg] == "Off" then
                        commandArray[myBuienRadarFlg] = "On"
                elseif otherdevices[myBuienRadarFlg] == "On" then
                    commandArray[myBuienRadarFlg] = "Off"
        end -- unparsable
    end -- empty result
Blah blah blah
jvdz
Post by jvdz »
I see you didn't change line 80 yet as suggested as fix a couple of posts ago or you do you like to see the other solution?
Maybe this script helps to explain the issue .... just save this is a test.lua file and run this with lua from the commandline:
tmp = "123,456789|10:00\r\n"
print("-- the original issue after buienradar changed the value to include decimals using a ,")
	print("Data:",k,v)
	kn = tonumber(k)
	print("Result:",kn,v)
print("")
print("-- proposed fix in regex")
	print("Data:",k,v)
	kn = tonumber(k)
print("")
print("-- the second option replace , with .")
	print("Data:",k,v)
	k = k:gsub(",",".")
	kn = tonumber(k)
Jos
HansieNL
Post by HansieNL »
@jvdz Runned your LUA script and it makes clear what's happening with the comma.
I would like to see the other solution (replace the comma for a decimal point).
If you have time can you show that solution?
Thanks in advance.
Blah blah blah
jvdz
Post by jvdz »
Mmm ... that one is in that script too ... in the last part ;)
HansieNL
Post by HansieNL »
jvdz wrote: Sunday 09 January 2022 18:31 Mmm ... that one is in that script too ... in the last part ;)
Ok. I hope that I understand it well :?
    k = k:gsub(",",".")  -- replace the comma for a decimal point
    kn = tonumber(k)
Blah blah blah
jvdz
Post by jvdz »
Correct..
madpatrick
Domoticz version: 2025.1
Post by madpatrick »
I'm using this script for a long time and it is still working great.
For those using it i've transfered the LUA script to DZ
Maybe useless action, but i'm understanding DZ a little bit better and all my scripts are in DZ.
For those who are interested here with my script
local scriptName    = 'Buienradar'
local scriptVersion = "2.0"
local scriptVar     = '-=# ' .. scriptName .. ' # v' .. scriptVersion.. ' #=-'
local LOG_LEVEL     = domoticz.LOG_STATUS
-- create dummy text device from dummy hardware 'Buienradar'
-- create dummy rain sensor from dummy hardware 'RegenData'
    active = true,
        timer = { 'every 5 minutes' },
        --devices = {290},
    logging = {
        level  = LOG_LEVEL,
        marker = scriptVar
    execute = function(dz)
        -- Devices
        local rainDevice        = dz.devices('RegenData')   -- create dummy rain sensor from dummy hardware 'RegenData'
        local textDevice        = dz.devices('Buienradar')  -- create dummy text device from dummy hardware 'Buienradar'
        local latitude          = string.format('%.2f', dz.settings.location.latitude)
        local longitude         = string.format('%.2f', dz.settings.location.longitude)
        local counter           = 0
        local maxRainNowRaw     = 0
        local rainNowAverage    = 0
        local maxRainSoonRaw    = 0
        local firstRainTime     = ""
        local maxRainRaw        = 0
        local statusText        = "Voorlopig droog"
        local function executeCommandWithRetries(command, maxRetries)
            maxRetries = maxRetries or 1
            local output = ""
            while output == "" and maxRetries > 0 do
                maxRetries = maxRetries - 1
                local process = assert(io.popen(command, 'r'))
                output = assert(process:read('*a'))
                process:close()
            return output
        local function rawToMillimeters(rawValue)
            return 10 ^ ((rawValue - 109) / 32)
        local function formatNumber(value, decimals)
            decimals = decimals or 1
            return string.format("%." .. decimals .. "f", value)
        dz.log("Start ophalen Buienradar data...", dz.LOG_INFO)
        local curlCommand = "curl --max-time 3 -L -s 'https://gpsgadget.buienradar.nl/data/raintext?lat=" .. latitude .. "&lon=" .. longitude .. "'"
        local buienradarData = executeCommandWithRetries(curlCommand, 3)
        if buienradarData == "" then
            dz.log("Geen data ontvangen van Buienradar", dz.LOG_ERROR)
            return
        for rawRainValue, timeString in buienradarData:gmatch("(%d+).-|(.-)\r?\n") do
            local rainValue = tonumber(rawRainValue)
            if counter <= 1 then
                if rainValue > maxRainNowRaw then maxRainNowRaw = rainValue end
                if rainValue > 0 then rainNowAverage = rainNowAverage + rawToMillimeters(rainValue) / 2 end
            if counter <= 3 and rainValue > maxRainSoonRaw then maxRainSoonRaw = rainValue end
            if firstRainTime == "" and rainValue > 0 then firstRainTime = timeString end
            if rainValue > maxRainRaw then maxRainRaw = rainValue end
            counter = counter + 1
        if counter == 0 then
            dz.log("Kon Buienradar data niet ophalen", dz.LOG_ERROR)
            return
        if maxRainNowRaw > 0 then
            statusText = "Het regent nu " .. formatNumber(rawToMillimeters(maxRainNowRaw)) .. " mm"
            if maxRainRaw > maxRainNowRaw then
                statusText = statusText .. " tot " .. formatNumber(rawToMillimeters(maxRainRaw)) .. " mm"
        elseif maxRainSoonRaw > 0 then
            statusText = "Regen verwacht " .. formatNumber(rawToMillimeters(maxRainSoonRaw)) .. " mm"
            if maxRainRaw > maxRainSoonRaw then
        elseif firstRainTime ~= "" then
            statusText = formatNumber(rawToMillimeters(maxRainRaw)) .. " mm regen verwacht om " .. firstRainTime
        local currentRainTotal = tonumber(rainDevice.rawData[2]) or 0
        local updatedRainTotal = currentRainTotal + rainNowAverage / 12
        local rainNowRounded = formatNumber(rawToMillimeters(maxRainNowRaw) * 100)
        local updatedRainTotalRounded = formatNumber(updatedRainTotal)
        local rainUpdateString = rainNowRounded .. ";" .. updatedRainTotalRounded
        dz.log("Bijwerken regenmeter: " .. rainUpdateString, dz.LOG_INFO)
        rainDevice.update(0, rainUpdateString)
        if textDevice.text ~= statusText then
            dz.log("Bijwerken tekstdevice met: " .. statusText, dz.LOG_FORCE)
            textDevice.updateText(statusText)
            dz.log("Tekst ongewijzigd, geen update nodig", dz.LOG_INFO)
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2025.1 -=- Dashticz v3.14b on Tab8" =-
niki_lauda
Post by niki_lauda »
madpatrick wrote: Thursday 22 May 2025 19:41 Hi,
    active = true,
        --devices = {290},
    logging = {
        level  = LOG_LEVEL,
        marker = scriptVar
        -- Devices
        local counter           = 0
            local output = ""
                process:close()
            return output
            return
            return
Thx
