understanding devicechanged vs. otherdevices Topic is solved
RonkA
Domoticz version: 2025.1
Post by RonkA »
hello,
I have a problem understanding Devicechanged command,
   if (otherdevices['Switch on display2004'] == 'On') then
   print('switch is on')
This works ok, giving= LUA: switch is on
   if (devicechanged['Switch on display2004'] == 'On') then
gives [string "commandArray = {}..."]:7: attempt to index a nil value (global 'devicechanged')
As far as i understand devicechanged can be a status or a value, a status is stated either 'On' or 'Off" and a value can be a number..
Please help :?:
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
jvdz
Domoticz version: 4.107
Re: understanding
Post by jvdz »
That array is not there for time events... So ensure you set the event type to device when using the internal editor!
RonkA
Re: understanding devicechanged vs. otherdevices
Post by RonkA »
Whoa Fast....
Lua is set on all, should i try device?
jvdz
Post by jvdz »
Yeap... But i already said that. ;)
