Multiple actions on activation of script. Topic is solved
f14driver
Post by f14driver »
Maybe some one here can help me with a ( I hope) simple question but I can't seem to find the solution for it.
I have a presence script that is activating the alarm as soon as the mobile phone is out of wifi reach with my local network.
 if (devicechanged['Phonename'] == 'Off')  then
    print('AlarmPanel Arm Away')
    commandArray['Domoticz Security Panel']='Arm Away'
 if (devicechanged['Phonename'] == 'On')  then
    print('AlarmPanel Disarming')
    commandArray['Domoticz Security Panel']='Disarm'
I want to include two actions prior to activating the alarm, resetting the motion sensor group and the closing of all doors as soon as the script is triggered.
Both devices are grouped into groups so I can reset the devices all at once.
When I include the two groups into the script nothing happens so I guess the error is between the chair and the monitor ;)
Underneath the modification I made that does't work;
    commandArray['Bewgingsmelders uit']='Off'
    commandArray['Deuren dicht']='Off'
Could some of you shed a light on the error I seem to be making in order to get these to group automaticly reset when I leave the house ?
Many tanks in advance.
Re: Multiple actions on activation of script.
f14driver wrote: Tuesday 19 May 2020 10:01 Maybe some one here can help me with a ( I hope) simple question but I can't seem to find the solution for it.
You need to tell domoticz that the command is for a Group and not for a device
    commandArray['Group:Bewegingsmelders uit'] = 'Off' -- was there also a typo in the name of the group?
    commandArray['Group:Deuren dicht'] = 'Off'
elseif (devicechanged['Phonename'] == 'On')  then
    commandArray['Domoticz Security Panel'] = 'Disarm'
f14driver
Post by f14driver »
Thanks Waaren,
That works like a charm.
I just couldn't find the error but you made it very simple to fix.
And yes there was a type in one line indeed.
