I use some Lua scripts in Domoticz in "My automation scripts"
The Lua scripts works fine, but when I change the name from the Lua script and save these I get an error in the log.
The error log says that he can't find the Lua script name, problem is that Domoticz is looking for the old name and not for the new Lua script name.
How can i solve this problem?
Problem. "My automation scripts"***Solved*** Topic is solved
Knibor
- Domoticz version: Stable
- waaren
Re: Problem. "My automation scripts"
I cannot replicate this. Can you show the loglines and maybe some screenshots. Could be that I don't fully replicate your steps leading to this error in the log.Knibor wrote: Saturday 23 November 2019 15:20 The Lua scripts works fine, but when I change the name from the Lua script and save these I get an error in the log.
Knibor
Hereby the Log
I change the Lua name from 'Meter uitsplitsen' to '1.0 Meter uitsplitsen'
After it, I restart Domoticz, and the log file gives me this error log.
Hereby the Log
019-11-24 17:46:22.479 Status: dzVents: Error (2.4.19): module '1.0 Meter uitsplitsen' not found:
2019-11-24 17:46:22.479 no field package.preload['1.0 Meter uitsplitsen']
2019-11-24 17:46:22.479 no file '/usr/local/share/lua/5.2/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/usr/local/share/lua/5.2/1/0 Meter uitsplitsen/init.lua'
2019-11-24 17:46:22.479 no file '/usr/local/lib/lua/5.2/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/usr/local/lib/lua/5.2/1/0 Meter uitsplitsen/init.lua'
2019-11-24 17:46:22.479 no file './1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/home/pi/domoticz/scripts/dzVents/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/home/pi/domoticz/dzVents/runtime/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/home/pi/domoticz/scripts/dzVents/dzVents/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/home/pi/domoticz/scripts/dzVents/scripts/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/home/pi/domoticz/scripts/dzVents/../lua/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/home/pi/domoticz/scripts/dzVents/data/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/home/pi/domoticz/scripts/dzVents/modules/1/0 Meter uitsplitsen.lua'
2019-11-24 17:46:22.479 no file '/usr/local/lib/lua/5.2/1/0 Meter uitsplitsen.so'
2019-11-24 17:46:22.479 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-11-24 17:46:22.479 no file './1/0 Meter uitsplitsen.so'
2019-11-24 17:46:22.479 no file '/usr/local/lib/lua/5.2/1.so'
- waaren
Lua / dzVents cannot handle filenames with an extra dot in the name.Knibor wrote: Sunday 24 November 2019 18:01 Hereby the Log
Knibor
Re: Problem. "My automation scripts" ***Solved***
Thanks for the information
