Use "Enter" in output Telegram Notification Topic is solved
Brutus
Post by Brutus »
Normally you can send a Telegram message in LUA with the following command:
commandArray['SendNotification']='Subject#Text: '..Sensor..'#0'
I would like to create a more clean output with an "Enter" after the text so the Sensor data comes on the next line in the message.
commandArray['SendNotification']='Subject#Text: "enter" '..Sensor..'#0'
Is this possible? I can't find any thing on Wiki or the forum.
Greetings.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
SweetPants
Re: Use "Enter" in output Telegram Notification
Post by SweetPants »
Have you tried adding "\r\n" to the string?
Brutus
Post by Brutus »
SweetPants wrote: Saturday 15 September 2018 19:03 Have you tried adding "\r\n" to the string?
Thnx for your reply!
Can you please put that in my example? So i don't make a mistake.
28x Fibaro Modules
SMA Solar System
SweetPants
commandArray['SendNotification']='Subject#Text: \r\n'..Sensor..'#0'
Brutus
Post by Brutus »
SweetPants wrote: Saturday 15 September 2018 19:12 commandArray['SendNotification']='Subject#Text: \r\n'..Sensor..'#0'
That works like a charm, Thanx!!
Were did you find this :) ?
28x Fibaro Modules
SMA Solar System
SweetPants
Brutus wrote: Saturday 15 September 2018 19:16
It's just plane LUA, just googeld for it
