Beginner Troubles Topic is solved
Bernhard1
Domoticz version: 3.8356
Beginner Troubles
Post by Bernhard1 »
Hi, I need Help by my project. I will program a 2 point controller for a heating system.
Here my code:
if (devicechanged['Tempsensor']) then
    local hysteresis = 0.2
    if (otherdevices['Modus'] == 'MANUAL') then
        local setpoint = otherdevices['Setpoint MANUAL']
    elseif (otherdevices['Modus'] == 'AUTOMATIC') then
        local setpoint = otherdevices['Setpoint AUTOMATIC']
    if (otherdevices['Tempsensor'] < (setpoint - hysteresis)) then
        commandArray['Output'] = 'On'
        print('ON')
    elseif (otherdevices['Tempsensor'] > (setpoint + hysteresis)) then
        commandArray['Output'] = 'Off'
        print('OFF')
by changing the Tempsensor value I got this Error:
2017-10-10 20:13:36.868 Error: EventSystem: in 001: [string "commandArray = {}..."]:13: attempt to perform arithmetic on global 'setpoint' (a nil value)
and every minute i got this one:
2017-10-10 20:14:00.489 Error: EventSystem: in 001: [string "commandArray = {}..."]:3: attempt to index global 'devicechanged' (a nil value)
BlueMoon
Domoticz version: 3.8153
Re: Beginner Troubles
Post by BlueMoon »
Try to declare setpoint before your if/else statement, so right after you declared hysteresis. Then give it its value within the if/else
I'm not a lua expert, but I believe the scope of the setpoint value is now only the within the if block, and another one within the else block.
Bernhard1
Post by Bernhard1 »
I have changed the code:
    local setpoint = 0
        print('ON')
        print('OFF')
and the first error changed to
2017-10-10 19:47:49.311 Error: EventSystem: in 001: [string "commandArray = {}..."]:16: attempt to compare string with nil
the secound is the same :(
BlueMoon
Post by BlueMoon »
Hmm, I looked over that one. Is your script a 'device' script? You should see it in the filename of the script.
It seems to complain about all device-related stuff, which not allowed of the script of the wrong type.
emme
Domoticz version: latest
Post by emme »
what kind of device are setpoint MANUAL and setpoint AUTOMATIC ?
try also to declare them forcing the tonumber conversion:
setpoint = tonumber(otherdevices['Setpoint MANUAL'])
setpoint = tonumber(otherdevices['Setpoint AUTOMATIC'])
ciao
M
"We always done this way"
Bernhard1
Post by Bernhard1 »
Thanks a lot now it works perfekt!
I have changed the settings from "All" to "Device" which one caused
and i have added the tonumber function several times in my code wich caused the secound error
dannybloe
Post by dannybloe »
I strongly suggest that you start writing scripts using dzVents as that is much easier for beginners (an much more powerful). Check the wiki for dzVents and the forum for dzVents.
emme
Post by emme »
dannybloe wrote: Thursday 12 October 2017 8:46 I strongly suggest that you start writing scripts using dzVents as that is much easier for beginners (an much more powerful). Check the wiki for dzVents and the forum for dzVents.
dzVents would look something like this...
	    devices = {
			'Tempsensor',
	execute = function(dz, devTemp)
		local devModus = dz.devices('Modus').value
		local setPoint = 18   -- let's give at least a value to it to avoid nil errors
		if devModus == 'MANUAL' then
			setPoint = dz.devices('Setpoint MANUAL').setPoint
		elseif devModus == 'AUTOMATIC' then
			setPoint = dz.devices('Setpoint AUTOMATIC').setPoint
		if devTemp.temperature < (setPoint - hysteresis) then
			dz.devices('Output').switchOn().checkFirst()
			dz.log('It's getting cold here... Let's heat it up for a while...',dz.LOG_FORCE)
		elseif devTemp.temperature > (setPoint + hysteresis) then
			dz.devices('Output').switchOff().checkFirst()
			dz.log('Uh... I'm fine... Let me stop this...',dz.LOG_FORCE)
Bernhard1
Post by Bernhard1 »
Thanks for your suggestion! dzVents is better for beginners in domoticz, Wiki for it is really great Thanks!!!
