Hi Folks,
I have automated my garden watering but I am facing a problem:
I have a rainmeter and a uservariable "regenteller"
what I want is this:
when there has been no rain during the past 24 hours (derived from my rainmeter) the uservariable should be risen with 1.
when I make a script in lua where I say
if (regenmeter==0 and hour == 23 and minute== 10) then
the uservariable gets raised with about 60 (all minute 10)
when I include seconds the update sometimes fails and regenteller i not raised.
Is there a way to simply raise regenteller with 1 when there was no rain and the time is at a certain point?
thanks for your replies
Jan
Garden watering Topic is solved
JuanUil
- Domoticz version: 4.11083
Garden watering
Lorccan
Re: Garden watering
(I think I understand you, but do post back if not!)
If your conditional test is correct, you just need to say:
regenteller = regenteller+1
If you need to use another variable to increase the value of regenteller, you need to ensure that you round up or down so that it's also an integer:
regenteller = regenteller+math.floor(othervariable)
JuanUil
Re: Garden watering
Hi Lorccan,
Thnx for your reply.
I do exactly what you said:
regenteller is regenteller+1
the problem is that during minute 10 regenteller is raised constantly with 1 until minute is 11 so regenteller is then 60 or so.
When I include the seconds so hour==23 minutes==10 and seconds ==1 then sometimes there is no raisng of regenteller.
jan
jan
Lorccan
Re: Garden watering
Ah, got it!
How about making a dummy switch that you turn on once a day with a timer (e.g. At sunset). Then you use a device script to catch the 'On', check your rain meter, increment the var if necessary. You can then either switch the dummy off in the script or have an auto off after some seconds in its definition.
- Egregius
- Domoticz version: v2024.7
Re: Garden watering
Why not retrieve the history of your rainmeter and go from there?
I'm currently also developing something for this. All tough I don't have a rainmeter.
My plan is to store the rain predection, an average of 3 weather providers, in a SQL table. Grab the data of the last 48 hours. That combined with the rain prediction of the next 48 hours should be good enough to decide if the garden needs water or not.
zicht
- Domoticz version: 2023.1+
Re: Garden watering
time = os.date("*t")
if((time.min % 3)==0)then
>>>> yourthing to fo with if then else and counter comes here'
regenteller=regenteller +1
endJust change 3 to 10 in your case.
Make sure it is in a TIME script otherwise it would fire during the minute every time a device reports it status.
Hope this helps !
JuanUil
Re: Garden watering
Thanx zicht,
that works. As soon as I have the code completew I will post it so that evrybody can use it
Jan
Jan
