Ran into a problem.
While working with some LUA scripts, I wanted to save some statements into a separate lua script file for later use.
Created a new script (triggered by ALL), and stored the statements.
Forgot to make the script inactive....
Next I saw was a massive dump on the log: "script does not return commandArray".
After that Domoticz simply gave up, nothing worked.
I tried to stop/start, but nothing comes up.
Is there a way to manually remove that LUA script from the Domoticz database?
help...! Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: V2024.7
Re: help...!
workaround is also by editting domticz.db
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Re: help...!
disable script is also possible by editting domoticz.db
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
