dzvents entsoe http request failing Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
willemd
Domoticz version: 2026.3
Post by willemd »
For years I have been running async http requests from dzvents to get entsoe prices through their API, until Sep 7th...
Now I just get a response 403 "Forbidden" instead of a list of prices.
I have tried the following analysis:
1) run the same http command from a PC browser : no problem
2) run the same http command with a curl call (on the command line) on the domoticz machine : no problem
3) run the same command with a async shell request running curl from dzvents : no problem (so this is a workaround for now)
so it is only the async http request from domoticz that is triggering an error.
The problem first occurred after the entoe migration to a new platform. For some reason this triggered an incompatibility with the async http request from domoticz. I don't have any info on details of the entsoe migration. The feedback shows that Microsoft-Azure-Application-Gateway/v2 is involved in the creation of the 403 response.
I don't see much usefull info in the domoticz log that could help solve this. Just HTTP/1.1 response: 403 ==>> Forbidden
Anyone with similar experience? Any clue how to get the http request working again, instead of using the shell command as a workaround?
Re: dzvents entsoe http request failing
What version of Domoticz are you on? Still 2024.1 as in your profile?
willemd
Post by willemd »
No, latest stable 2026.3
I think my question can also be "how is the full http get command that dzvents is sending with async http different from curl" ? That difference triggers a different reaction from the server.
willemd
Post by willemd »
I still have not solved this issue. I even generated a new security token for entsoe api but the results remains the same.
It is working in a browser, it is working with curl from command line, it is working with curl from a dzvents shell command, it is working with request get in a python program, it is NOT working from a dzvents http command.
The reponse is "403 Forbidden", which normally should only be given if the authorisation token is incorrect.
So a dzvents http call does something to the token that curl does not ?
The dzvents code is as follows (token redacted):
domoticz.openURL({
 	url = 'https://web-api.tp.entsoe.eu/api?securityToken=XXXXXXXXXXXXXXX&documentType=A44&in_Domain=10YNL----------L&out_Domain=10YNL----------L&periodStart=202609210000&periodEnd=202609212200' ,
    	method = 'GET',
    	callback = 'entsoe',
BobKooi
Post by BobKooi »
Hello willemd,
I had the same problem en because I’m no expert I asked AI for help.
Question: When I make an openURL call to entsoe.eu from the browser, everything works fine. If I make the exact same call from dzVents, I get an error: "HTTP/1.1 response: 403 ==>> Forbidden". What could be the cause of this?
The answer..
This issue is almost certainly caused by a missing User-Agent header in your dzVents script, or a mismatch in how the API token.
Probable first cause: 1. Missing User-Agent Header (Most Likely)
By default, dzVents/Domoticz sends an empty or generic User-Agent. You can resolve this by explicitly adding a browser-like User-Agent string inside the headers parameter of your openURL call.
Like this:
domoticz.openURL({
url = 'https://entsoe.eu&...', -- Your ENTSO-E URL
method = 'GET',
headers = {
['User-Agent'] = 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36'
callback = 'entsoe_callback'
So I added the User-Agent header and for me it solved the problem.
Good luck!
BobKooi
Post by BobKooi »
By the way, for my call also the response was changed.
If I’m correct I got now the day ahead prices per 15min.
I receiver 96 positions, so I suppose for a total day overview this means the data is divided in quarters of an hour, 15 min interval instead of hours what I receives before.
willemd
Post by willemd »
BobKooi wrote: Thursday 01 October 2026 18:49 Hello willemd,
The answer..
Like this:
domoticz.openURL({
method = 'GET',
headers = {
Good luck!
Thank you very much, this indeed solves the problem.
So after the upgrade on entsoe side, this is now required and because dzvents did not send it, it failed.
Apparently curl already includes it in the message then, otherwise that would also have failed.
willemd
Post by willemd »
BobKooi wrote: Thursday 01 October 2026 20:02 By the way, for my call also the response was changed.
Correct, you are receiving 15 min interval prices, but I did receive that also before (I think since October 1st last year when it was introduced?).
I am calculating hourly averages while processing because my contract still uses hourly averages.
