For years I have been running async http requests from dzvents to get entsoe prices through their API, until Sep 7th...
Now I just get a response 403 "Forbidden" instead of a list of prices.
I have tried the following analysis:
1) run the same http command from a PC browser : no problem
2) run the same http command with a curl call (on the command line) on the domoticz machine : no problem
3) run the same command with a async shell request running curl from dzvents : no problem (so this is a workaround for now)
so it is only the async http request from domoticz that is triggering an error.
The problem first occurred after the entoe migration to a new platform. For some reason this triggered an incompatibility with the async http request from domoticz. I don't have any info on details of the entsoe migration. The feedback shows that Microsoft-Azure-Application-Gateway/v2 is involved in the creation of the 403 response.
I don't see much usefull info in the domoticz log that could help solve this. Just HTTP/1.1 response: 403 ==>> Forbidden
Anyone with similar experience? Any clue how to get the http request working again, instead of using the shell command as a workaround?
dzvents entsoe http request failing
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2026.3
Re: dzvents entsoe http request failing
What version of Domoticz are you on? Still 2024.1 as in your profile?
willemd
No, latest stable 2026.3
I think my question can also be "how is the full http get command that dzvents is sending with async http different from curl" ? That difference triggers a different reaction from the server.
willemd
I still have not solved this issue. I even generated a new security token for entsoe api but the results remains the same.
It is working in a browser, it is working with curl from command line, it is working with curl from a dzvents shell command, it is working with request get in a python program, it is NOT working from a dzvents http command.
The reponse is "403 Forbidden", which normally should only be given if the authorisation token is incorrect.
So a dzvents http call does something to the token that curl does not ?
The dzvents code is as follows (token redacted):
domoticz.openURL({
url = 'https://web-api.tp.entsoe.eu/api?securityToken=XXXXXXXXXXXXXXX&documentType=A44&in_Domain=10YNL----------L&out_Domain=10YNL----------L&periodStart=202609210000&periodEnd=202609212200' ,
method = 'GET',
callback = 'entsoe',
BobKooi
Hello willemd,
I had the same problem en because I’m no expert I asked AI for help.
Question: When I make an openURL call to entsoe.eu from the browser, everything works fine. If I make the exact same call from dzVents, I get an error: "HTTP/1.1 response: 403 ==>> Forbidden". What could be the cause of this?
The answer..
This issue is almost certainly caused by a missing User-Agent header in your dzVents script, or a mismatch in how the API token.
Probable first cause: 1. Missing User-Agent Header (Most Likely)
By default, dzVents/Domoticz sends an empty or generic User-Agent. You can resolve this by explicitly adding a browser-like User-Agent string inside the headers parameter of your openURL call.
Like this:
domoticz.openURL({
url = 'https://entsoe.eu&...', -- Your ENTSO-E URL
method = 'GET',
headers = {
['User-Agent'] = 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36'
callback = 'entsoe_callback'
So I added the User-Agent header and for me it solved the problem.
Good luck!
The answer..
Like this:
domoticz.openURL({
method = 'GET',
headers = {
Good luck!
BobKooi
By the way, for my call also the response was changed.
If I’m correct I got now the day ahead prices per 15min.
I receiver 96 positions, so I suppose for a total day overview this means the data is divided in quarters of an hour, 15 min interval instead of hours what I receives before.
