update scripts don't work anymore
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
IanDury
Post by IanDury »
I'm using v2026.3 (build 18263) on a Linux x86_64 target and when running the updatebeta script I get an error:
# ./updatebeta
2026-09-16 08:46:47.421 >> Downloading latest beta version...
2026-09-16 08:46:47.539 >> ERROR: Problem downloading new Domoticz version!!
The wget command appears to get a 403 response apparently because of Cloudflare being used on the download server and wget doesn't know how to handle this:
wget -4 --show-progress -O "domoticz_beta.tgz" --no-check-certificate "https://www.domoticz.com/download.php?channel=beta&type=release&system=linux&machine=x86_64"
--2026-09-16 08:50:45--  https://www.domoticz.com/download.php?channel=beta&type=release&system=linux&machine=x86_64
Resolving www.domoticz.com (www.domoticz.com)... 188.114.97.0, 188.114.96.0
Connecting to www.domoticz.com (www.domoticz.com)|188.114.97.0|:443... connected.
HTTP request sent, awaiting response... 403 Forbidden
2026-09-16 08:50:45 ERROR 403: Forbidden.
Using the same URL from a browser works fine.
Anyone who can fix this?
fjongma
Domoticz version: 2024.4
Re: update scripts don't work anymore
Post by fjongma »
I don't know how to fix it, but have the same problem running updaterelease on V2026.2 to install 2026.3.
FunFair
Post by FunFair »
Same issue here. updaterelease and updatebeta don't work.
Can download domoticz via https://www.domoticz.com/downloads/ just fine on my pc.
IanDury
Post by IanDury »
gizmocuz
Post by gizmocuz »
This is because some little script kiddies are hammering our servers.
Sad... but for now, Cloudflare is to the rescue.
Domoticz in a docker container does not suffer from this
gizmocuz
Post by gizmocuz »
Should be working again
IanDury
Post by IanDury »
gizmocuz wrote: Monday 21 September 2026 18:35 Should be working again
It does. Thank you.
