beta 17447 to 17452 Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Dave21w
Domoticz version: Stable
beta 17447 to 17452
Post by Dave21w »
Update from 17447 to 17452 Domoticz fails to restart, tried on 2 different beta installs, same on both. a sudo systemctl restart domoticz does start it though.
Domoticz version: 2026.3
Re: beta 17447 to 17452
Did you update over webgui? Did you try to run manually:
sudo ./updatebeta
What hardware/OS are you running as it could be related to viewtopic.php?t=44457
Andreotti
Domoticz version: latest
Post by Andreotti »
Same here. 17452 does not start automatic. Manual restart does the trick.
Raspberry Pi 4 with Trixie13.4
Rik60
Post by Rik60 »
Maybe you have to wait a while, I have seen that when the counter reach 100, that when the counter could be at 130, the dashboard is back without a service restart
Dave21w
Post by Dave21w »
Update was done via the gui, have to wait until another update to see if it actually restarts then
Dave21w
Post by Dave21w »
Just updated to 17458 and now restarts OK :D
Andreotti
Post by Andreotti »
I waited long enough but I needed a manual restart on 17458 also.
The log says the service has started, but it looks like there's no connection to the database.
Rik60
Post by Rik60 »
Hmm, yesterday i did an update to 17437 without problems. Now the update again through the web ui, Domoticz didn't come online. Had to do a service restart. There is still something going on with the update procedure when using the web ui. After the service restart Domoticz was on 17459.
Andreotti
Post by Andreotti »
Same with 17459.
The log says the service has started.
But the files domoticz.db-shm and domoticz.db-wal are missing. After manual restart they are there again.
gizmocuz
Post by gizmocuz »
Andreotti wrote: Friday 20 March 2026 14:04 Same with 17459.
They suppose to be missing when the Domoticz service is shutdown properly. (you can google what these extensions mean)
try the following
sudo killall -9 domoticz
sudo service domoticz.sh start
This should get you up and running correctly, next try the web update
If it still does not work, just issue
cd domoticz
./updatebeta
rene2716
Post by rene2716 »
Next update 17477 won't install either, no progress shown and keeps coming back
Dave21w
Post by Dave21w »
Update to 17484 via WebUI all good
Rik60
Post by Rik60 »
No issues anymore. Updating though the web ui was ok. Tested with Bookworm and Trixie. Running Beta 17492 now.
Rik60
Post by Rik60 »
Updating through the web ui failed. After some time: No internet connection...The update log file showed that the update was finished. Updating was from 17494 to 17497. A domoticz service start did not help, had to do a service restart.
update.log
(25.03 KiB) Downloaded 62 times
gizmocuz
Post by gizmocuz »
@Rik
Just wanting to point out that I (and others) with multiple installations do not experience this issue.
As you are already in discussion with us on Github, it is not needed to create a forum post.
(cross posting is not allowed, and causes us double the work)
