Error: RFXCom: Error opening serial port!
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Doler
Post by Doler »
After some retries I succesfully migrated to beta build 17277 and converted to systemd control. Since that time my RFXCom won't start anymore stating that the serial port cannot be opened. The serial port is identified by serial/by-id and present in the harware configuration.
Is there a relation to the (many) latest changes? Are there ways to discover the cause of the problem?
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Doler
Re: Error: RFXCom: Error opening serial port!
Post by Doler »
Returned to beta 17252 and RFXCom is not giving a problem anymore. Sure it has something to do with changes to 17277. Will investigate this further.
I also noticed that beta 17277 forced reboots of the system. It happens muliple times per day with unknown frequency. I will (on my test system) disable all hardware and see what happens.
HvdW
Domoticz version: 2023.2
Post by HvdW »
KIS
Don't fuzz with beta if you want to stay out of trouble.
Bugs bug me.
