crash after Watchtower/Docker update to Domoticz V2025.2 (build 17268)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Huntback
Domoticz version: 2024.2
Post by Huntback »
NAS did a Watchtower update in Docker and Domoticz crashed
Log:
2026-02-25 13:00:28.418 Launch: Begin container self-repair
2026-02-25 13:00:28.630 Launch: End container self-repair
2026-02-25 13:00:28.632 Launch: Running customstart.sh
2026-02-25 13:00:28.650 Status: Domoticz V2025.2 (build 17268) (c)2012-2026 GizMoCuz
2026-02-25 13:00:28.650 Status: Build Hash: 5bae973be, Date: 2026-02-25 10:10:03
2026-02-25 13:00:28.650 Status: Startup Path: /opt/domoticz/
2026-02-25 13:00:28.665 Sunrise: 07:30:00 SunSet: 18:08:00
2026-02-25 13:00:28.665 Day length: 10:37:00 Sun at south: 12:49:00
2026-02-25 13:00:28.665 Civil twilight start: 06:56:00 Civil twilight end: 18:42:00
2026-02-25 13:00:28.665 Nautical twilight start: 06:17:00 Nautical twilight end: 19:21:00
2026-02-25 13:00:28.665 Astronomical twilight start: 05:38:00 Astronomical twilight end: 20:01:00
2026-02-25 13:00:28.706 Status: PluginSystem: Started, Python version '3.11.2', 4 plugin definitions loaded.
2026-02-25 13:00:28.716 Active notification Subsystems: email (1/13)
2026-02-25 13:00:28.718 Status: WebServer(HTTP) started on address: :: with port 80
corrupted size vs. prev_size
2026-02-25 13:00:28.719 Error: Domoticz(pid:1, tid:1('domoticz')) received fatal signal 6 (Aborted)
2026-02-25 13:00:28.719 Error: siginfo address=0x1, address=0x7f955511eeec
Synology - DS918+
RFXCOM - RFXtrx433XL (LAN)
Oregon - Weatherstation
Some KAKU, Impuls, TFA, etc.
gmarchionni
Re: crash after Watchtower/Docker update to Domoticz V2025.2 (build 17268)
Post by gmarchionni »
same as the other guy.
i believe you are running one of the latest beta. It probably had some problems?
Update to latest or update to officiale 2025.2.
The question is why are you running latest beta? Stick to the official 2025.2.
Latest beta is created at every commit, so once every while it might stop working. if this is a production system, stick to 2025.2. if it's a test version open a bug on github if you see that the problem remains for multiple versions.
Huntback
Post by Huntback »
i'm sorry, i'm using:
TAG:
latest
Synology - DS918+
gmarchionni
tag "latest" is the latest build available that is most probably a beta.
if it's not for testing and you want to stay on stable build you should probably use the tag 2025.1, 2025.2 etc.
don't downgrade now anyway because you might screw up the db. when the next official version is released you should change to 2026.1 or whatever version will be released.
If you use it for testing, that's different, and you should report on github i guess....(if it's not a temporary bug)
Huntback
Post by Huntback »
OK, but.....
Why isn't the Domoticz version number changed to the downloaded Latest/Beta Domoticz version number?
Because it currently shows (see log): Domoticz V2025.2 (build 17268)
While it should be: Domoticz V2026 (build 17268)!
Then I would have noticed earlier that I'm using Beta versions (which I actually don't want).
Synology - DS918+
Users browsing this forum: Doler and 1 guest
