After a database restore Domoticz doesn't come online, no devices found or no communication...
Did a service restart, after that domoticz was running normal. Tried this with a database backup and restore (no database changes) and after a powercycle of the Rpi3B+. Seen this also on earlier versions of the beta (2025.2 17057, 2025.2 17099 and 2502.2 17189).
Attached is a crash log after a database restore.
Domoticz crash after database restore Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Rik60
- Domoticz version: 2026.3
- domoticz_crash.log
- (41.66 KiB) Downloaded 79 times
Kedi
- Domoticz version: latest
Re: Domoticz crash after database restore
From the crashlog I can only see that you have a problem with libpython3.13.so and the Somfy plugin.
Rik60
Thanks.
Removed Somfy to test, problem still exist. I am on Trixie and Domoticz beta 2025.2 17198, going to test with an older os (Bullseye, Bookworm) and older Domoticz.
Am i the only one with this problem?
Rik60
Did some tests with another os (Bookworm) and Domoticz versions.
Trixie + Stable 2025.2 restore database Domoticz crash, restart domoticz service
Bookworm + Stable 2025.2 restore database Domoticz online Ok
Bookworm + beta 2025.2 17163 restore database Domoticz online Ok
Bookworm + beta 2025.2 17163 restore database from Trixie 2025.2 17163 Domoticz online Ok
Bookworm has Python 3.11
So, there is a problem with Trixie with python version 3.13?
Rik60
Saw that Gizmocus is working on it....#6577
Edit: Updated to last beta 17163, same problem. On trixie domoticz is crashing after database restore, on Bookworm not
Rik60
Gizmocuz has solved the issue. No issues anymore
