Orange PI PC with Armbian Trixie 6.12.57 Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Piter1973
Post by Piter1973 »
Hello
I'm trying to install Domoticz on my Orange PI PC running Armbian Trixie 6.12.57 ( v25.11 rolling for Orange Pi PC running Armbian Linux 6.12.51-current-sunxi ). But there is a problem during installation - the installation stops
I install using ( I install it on the domoticz user account )
sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
::: Your system is up to date! Continuing with Domoticz installation...
:::    Checking for apt-utils... installed!
:::    Checking for whiptail... installed!
:::    Checking for git... installed!
:::    Checking for curl... installed!
:::    Checking for unzip... installed!
:::    Checking for wget... installed!
:::    Checking for sudo... installed!
:::    Checking for cron... installed!
:::    Checking for libudev-dev... installed!
:::    Checking for libcurl4...domoticz@orangepipc:~$
I don't know where to download the necessary package
or
Maybe someone can recommend a better version of Linux?
Domoticz version: 2026.3
Re: Orange PI PC with Armbian Trixie 6.12.57
What happens if you run
sudo apt-get install libcurl4
The next step is to check libusb-0.1
So perhaps there is going wrong.
Piter1973
Post by Piter1973 »
I guess this won't be easy to solve
root@orangepipc:~# sudo apt-get install libcurl4
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package libcurl4 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  libcurl4t64
E: Package 'libcurl4' has no installation candidate
root@orangepipc:~# ^C
root@orangepipc:~# sudo apt-get install libcurl4t64
libcurl4t64 is already the newest version (8.14.1-2).
libcurl4t64 set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
It might be easier to change the hardware - I have a Raspberry Pi 3 - I found a system for it, raspioos bookworm. Maybe it will be easier with Pi.
It seems the install script is not ready for Trixie yet. You could try to put bookworm on the armbian and give it another try.
Or use the docker way, then there is no issue at all.
I got notified the install script has been updated for trixie. Please try again.
Piter1973
Post by Piter1973 »
Woow, Thanks :D :D
Domoticz is installed
But the first time I connect via the website, I need a login and password. I didn't set anything up. Is there a default login and password?
This is a new linux install and a new domoticz install.
It was shown in the installed popup, but you can always use the wiki: https://wiki.domoticz.com/Getting_started it shows the default account and password there too. And guides you through initial setup.
