Help! Device gone in Domoticz, how to restore that device's historic data from old backup?
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
andrehj
Post by andrehj »
Somehow a device with a lot of historic data is no longer present in Domoticz (also in Setup → Devices) :( . Don't understand how that happened, I must have deleted it accidentally... :oops:
From the output of scripts I can see that it's missing since the 8th of June.
I have a domoticz_backup.db from June 2nd.
Is it possible to retrieve the device data (table) from that old backup and somehow insert it into my current database? Is there a how-to which explains how to do that? From my scripts I know the correct Device Idx.
From other devices and scripts I can estimate the values of the missing days. It would be nice if I could insert these into the table as well. But how do I accomplish that?
Thanks in advance for any help,
Andrehj
Domoticz version: 2024.7
Re: Help! Device gone in Domoticz, how to restore that device's historic data from old backup?
See the database merge tool mentioned in this topic: viewtopic.php?p=312243#p312243
Varazir
Post by Varazir »
waltervl wrote: Thursday 03 July 2025 15:55 See the database merge tool mentioned in this topic: viewtopic.php?p=312243#p312243
I can't download the file
https://releases.domoticz.com/releases/ ... BMerger.7z
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
jvdz
Domoticz version: 4.107
Post by jvdz »
Varazir
Post by Varazir »
jvdz wrote: Thursday 03 July 2025 20:09 Try: https://releases.domoticz.com/release/t ... BMerger.7z
Thanks it worked, It looked strange at first but didn't try to remove the extra.
andrehj
Post by andrehj »
Thanks for the help!
However, as far as I understand, that tool can only merge some specific tables, or all tables. I just need to gather my historic data from one specific Idx, and integrate that into the current database.
I don't understand how I can do that with this tool.
Do I have to simply run
DomoticzDBMerger.exe --inputdb=olddatabase.db --outputdb=currentdatabase.db --merge-all
and hope that it works?
Or can I use the command
--transfer-old=idx --transfer-new=idx
to copy one idx from the old db to the current db? And than by keeping the idx the same it should just copy that index?
DomoticzDBMerger.exe --inputdb=olddatabase.db --outputdb=currentdatabase.db --transfer-old=137 --transfer-new=137
And will the latter work if a device with the new index is not yet present in the output database? Or do I have to create it first and let the merger simply fill that data?
So many questions...
Too bad there is no more elaborate help for this tool.
