Strange Blockly layout
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
njlammerts
Domoticz version: 2022.2
Post by njlammerts »
After the 2025 update I checked my blocky environment, as everything seems to work it was more then 2-3 weeks that I went into blocky and I found the layout completely f*cked up ;-) .
Scherm­afbeelding 2025-05-29 om 20.17.11.png (170.14 KiB) Viewed 59 times
when moving the switches out and back again the layout is reconditioned, but after saving, leaving Blockly and coming back, the same problem appears
Scherm­afbeelding 2025-05-29 om 20.17.39.png (183.22 KiB) Viewed 59 times
solarboy
Domoticz version: 2024.6
Re: Strange Blockly layout
Post by solarboy »
This has been a blockly glitch since a few generations. Opening and closing the event and refreshing the page should fix it.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
njlammerts
I have 9 itms and 8 are "garbage" . I can refresh, save, open as much as I want, but they stay the same.
When I move the internal items, they go to normal proportions, but when I save and open again, they are messed up again.
This happend after last Domoticz update, in the 2024 version I had no problem.
1 item has no problem ?? (Strange)
Scherm­afbeelding 2025-05-30 om 09.49.15.png (232.36 KiB) Viewed 25 times
