Temperature setpoint cannot be negative in app Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Hobbyman
Post by Hobbyman »
In the webinterface I can enter a negative value as setpoint for a custom temperature setting (when range is also set from e.g. -15 to +25), but in the Domoticz app this is not possible (although it can show a negative value when set in the webinterface).
Can this be fixed or did I make a mistake?
Browser setting.jpg (131.67 KiB) Viewed 2051 times
Browser details.jpg (152.83 KiB) Viewed 2051 times
Domoticz app.jpg (91.28 KiB) Viewed 2051 times
Domoticz version: 2025.1
Re: Temperature setpoint cannot be negative in app
Works for me with your settings. Only sometimes the value is not 1 digit but a lot more.
Users browsing this forum: Rik60 and 1 guest
