Please use template to report bugs and problems. Post here your questions when not sure where else to post Only for bugs in the Domoticz application! other problems go in different subforums!
Forum rules
Never a problem in the past, last 4 weeks did not use Domoticz, and now suddenly stumbling on this message when trying to get export from Domoticz of graphs in jpeg-format or png-format
Sorry, you have been blocked
Your are unable to access export.highcharts.com
Why have I been blocked?
Most likely your request lack the required HTTP referer and user-agent headers. Also, chart configurations that fail to render properly, excessive requests ("hammering") and similar will result in progressively longer periods of blocking.
What can I do to resolve this?
First of all check your headers, and also read our Fair Usage Policy to make sure your usage is not significantly above expected levels. Blocking is based on your IP, which may be shared, so blocking might not be caused by your actions.
Any explanation why this now happens, and how to remedy?
Because unclear to me what is meant in 2nd and 3rd section, because I rarely ask for export of graphs.
Common = KAKUs+3*PVLogger+PWS_TFA_Nexus plus series of 'satellites' for dedicated interfacing, monitoring & control.
I have the same issue I just noticed.
So it is not you only. Highcharts.com library is used to create the graphs. It seems they have an issue or more likely got more strict lately on how to adress their servers.
I move it to section bugs because perhaps something has to be changed on Domoticz side.
There seems to be something different than just a change of policy by Google.....
Graphics appear 'undisturbed' ( in my opinion meaning that Highcharts still applied for the compilations),
but only export seems to be affected by the changes at Google.
For myself pragmatically solved by application of Nimbus for screenshot. Might imply that for Domoticz the issue might be solved by application of a different excport-function.
Last edited by Toulon7559 on Friday 08 November 2024 23:24, edited 2 times in total.
Toulon7559 wrote: Friday 08 November 2024 12:58
There seems to be something different than just a change of policy by Google .....
Graphics appear 'undisturbed' ( in opinion meaning that Highcharts still applied for the compilations),
This is NOT a policy change of Google but a policy change of Highcharts. Domoticz is using their servers to create the PNG/JPG file. And Highcharts is now limiting the access to their servers to prevent overload.
Highcharts also delivers a function to create the PNG/JPG file of the graph by a script on your domoticz server (without using the Highcharts servers) but that seems difficult to implement.
You are right:
sorry to have mixed up Google and Highcharts ........
With my latest message only intended to tell that in Domoticz the generation of the graphs is still OK for viewing in Domoticz,
but that 'problem' seems to be export of the graph, which can be 'escaped' by application of screenshot on the view.
The issue has been "solved" by removing the export function from the charts menu as it was too complicated to implement the local export Highcharts function. Workaround is to take a screenshot from your local system. https://github.com/domoticz/domoticz/issues/6188
