Thanks for this nice update.
I have an issue with the Enever add. I have a token and configured the hardware part, but don't see the four devices with costprice etc.
Please help?
Regards Kees
Enever Hardware gateway issues Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2024.7
Re: Enever Hardware gateway issues
Do you have "Accept new Hardware Devices" switched on in menu Setup - Settings?
If so what does the log (menu Setup - Log) say when you enable Enever in Domoticz? Any error messages?
- gizmocuz
Also check under Setup->Devices if you get new devices
Thx. I did all that, thanks to your advice I now enabled new hardware permanently and this works. Thanks.
