I just did the update from 2024.4 to 2024.5 and then to 2024.6 and I have issue to acces domoticz behind my apache proxy.
I dit a test to rollback to 2024.4 and the acces sis workgin fine after the rollback.
Is there any reason for a behavioure change using a proxy ?
There is not authentification needed on Domototicz itself the authentification is done at proxy level on my case .
Version: 2024-06
Platform: Linux / Raspberry with Apache2 as proxy
The proxy is set with :
<Proxy *>
AuthType Basic
AuthName "Protected Intranet Proxy"
AuthBasicProvider file
AuthUserFile "<mypasswd file>"
<RequireAny>
Require valid-user
Require ip 192.168.1.0/24
</RequireAny>
</Proxy>
ProxyPreserveHost On
ProxyRequests Off
# ProxyPass/Reverse directives
<Location "/domo/json">
ProxyPass "ws://pi3:8080/json"
</Location>
ProxyPass /domo/ http://pi3:8080/
ProxyPassReverse /domo/ http://pi3:8080/
ProxyPass /wiki/ http://pi3:80/wiki/
ProxyPassReverse /wiki/ http://pi3:80/wiki/
Only acces of domoticz is affected and only from the internet, local access using proxy is working fine.
