my log file show an error in a deleted dzVents script.
The script is not in /home/pi/domoticz/scripts/dzVents/generated_scripts/
Also, creating and deleting a script with the same name does not solve the problem.
Any ideas?
deleted script in log?! Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2024.7
Re: deleted script in log?!
How did you delete the Dzvents script? From the events system editor (menu Setup - Other - Events)?
Is the Dzvents script name in the generate scripts list in the log (menu setup - log) if you press on another active script in the events editor?
I worked from the front-end menu Setup - Other - Events.
Problem solved. Script with another name had the wrong marker, that made me look for dzDeurbel instead of dzSirenOff
