external script won't run from dzventsz
Hansh
Domoticz version: 2025.1
Post by Hansh »
I hope I'm asking this question in the right place.
I have a problem with starting a script from dzvents. The script won't start no matter what I've done so far, even consulting ai hasn't provided a solution. (I end up in a cricel of solutions).
This is my latest version of the script.
		devices = {
			'3d printen'
	logging =
        level = domoticz.LOG_INFO, -- set to LOG_ERROR when tested and OK
        marker = '3D printen',
	    if device.state== 'On' then
	        domoticz.devices('3D systeem').switchOn()
	    if device.state== 'Off' then
		domoticz.log("3D systeem is shutting down in progres")
	        --python3 /home/pi/scripts/octopi_shutdown.py  (
	        domoticz.utils.osExecute("/bin/bash octopi_shutdown.sh")
	        --domoticz.utils.osExecute("ssh [email protected] 'sudo poweroff'")
	        domoticz.devices('3D systeem').switchOff().afterSec(30)
		domoticz.log("3D systeem is down")
in an earlier version of domoticz the command ( now in use 2025-1)
worked fine and stopped octopi
What I tried / did:
the two raspberries can log in via ssh without passwords also for the sudo commands no passwords are needed anymore. If I enter "ssh [email protected] 'sudo poweroff'" in a terminal then the octopi.local stops as expected. But not via dzvents. (tried as user pi and root)
tried with python intermediate step. When running this python script from a terminal the octipi.local also stops here but also not via dzvents
You would think it's a rights problem. Domoticz is executed by the owner PI and all rights are set so that the owner pi can access everything and can start all relevant folders and files have the rights 777.
Even after "sudo chmod 777 -R ./home/pi" it doesn't work from dzvents
os.Execute is recognized by domoticz.
Messages from the domoticz log are and remain the same no matter what I do. And I don't get a single message from the scripts, not even that it's running. (the scripts are full of log messages also to log files)
2025-06-15 11:22:26.786 Status: User: Hans (IP: 192.168.0.xxx) initiated a switch command (148/3d printen/Off)
2025-06-15 11:22:26.814 dzVents: Handling events for: "3d printing", value: "Off"
2025-06-15 11:22:26.814 dzVents: 3D printing: 3D system is shutting down in progress
2025-06-15 11:22:26.816 dzVents: 3D printing: 3D system is down
I'm out of options
Anyone have any ideas
All my texts are translated from Dutch to English by Google translate>
Sorry for weird sentence structure
willemd
Domoticz version: 2024.1
Re: external script won't run from dzventsz
Post by willemd »
So clearly your script is triggered and runs as expected, except for this line
You did not mention you tried running exactly this command from a command line but I assume this also works?
Can you put more debugging into that shell script? Can you get any error logging from that shell script? Is that shell script executed but maybe some statements that are within the shell script are not?
Hansh
Post by Hansh »
thanks for the reply
yes i had already executed it via a command line. i called this a terminal in my post.
The scripts are provided with extensive log options. When executing the script in a command line i get all ok messages that i expect and the script does what it should do.
If i do it via dzvents then nothing happens at all not even a log output. only a message in the domoticz log as mentioned in the post.
it seems like a security problem but i have allowed and released everything and still it does not work from domoticz. . possibly an option in domoticz is not set right. But which one
jvdz
Domoticz version: 4.107
Post by jvdz »
You also set the Execute (x) bit on the file with chmod +x ?
Hansh
Post by Hansh »
jvdz wrote: Sunday 15 June 2025 22:16 You also set the Execute (x) bit on the file with chmod +x ?
i had set the Executebit (+x) in both files and folders with "sudo chmod 777 -R ./home/pi" (777 stands for rwxrwxrwx) and that didn't help either
It remains a mystery to me :?:
madpatrick
Post by madpatrick »
maybe this helps a bit
viewtopic.php?t=35237
Here they are using "os.execute" and not "domoticz.utils.osExecute"
and
https://wiki.domoticz.com/DzVents:_next ... _execution
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2025.1 -=- Dashticz v3.14b on Tab8" =-
Domoticz version: 2024.7
Also make sure you use full paths in the scripts, also in the sub-scripts. Like for example
/bin/bash /home/pi/octopi_shutdown.sh
jannl
Domoticz version: 2022.2
Post by jannl »
Are you using docker?
