rawData cutting off value  [Solved]
smartypantsuk
Domoticz version: 2021.1
Post by smartypantsuk »
I'm trying to get the full value of rawData which should be something like "19.0 C, (5.0 C), HeatingOff"
but it's only giving "19.0" and missing the rest off.
Is that because it's an array or lookup table that needs to be processed differently?
How can I fetch the whole value as a string or separate values please?
Software:
Windows 10 Pro
Domoticz & Homeseer Home Assistant
HA-Bridge & Traccar
Jellfin Media Server
Hardware:
ASUS Mini Core i5 / 8GB RAM
Heating: Honeywell Evohome + HGS80
Fibaro Z-Wave Dimmers/Switches
Domoticz version: 2025.1
Re: rawData cutting off value
So you are referring to evohome data? From what device type (controller, relay, zone)?
Did you check the evohome dzvents documentation? https://www.domoticz.com/wiki/DzVents:_ ... troller.29
To get the mode you can use the .mode function.
smartypantsuk
In this instance I'm trying to pull the whole value of the Data key which is in rawData. I am using evohome but it's not specific to evohome. I
Software:
Windows 10 Pro
HA-Bridge & Traccar
Hardware:
Re: rawData cutting off value  [Solved]
Did you try .sValue ?
smartypantsuk
waltervl wrote: Sunday 07 May 2023 14:08 Did you try .sValue ?
No I don't know what that is
Software:
Windows 10 Pro
HA-Bridge & Traccar
Hardware:
Check the dzvents documentation and then the general devices part https://www.domoticz.com/wiki/DzVents:_ ... ll_devices
To use example:
svaluedata = domoticz.devices('your device').sValue
smartypantsuk
waltervl wrote: Sunday 07 May 2023 18:51 Check the dzvents documentation and then the general devices part https://www.domoticz.com/wiki/DzVents:_ ... ll_devices
To use example:
That actually provides what I need.
It reads as a string with the values separated by semi-colons, but that's fine.
This is what I get "20.16;5.00;HeatingOff" so I can work with that.
Thanks for you help @waltervl
Software:
Windows 10 Pro
HA-Bridge & Traccar
Hardware:
You are welcome. Still wondering why you are doing this as you seem to want to split the again. And dzvents already does this splitting for you.
smartypantsuk
waltervl wrote: Monday 08 May 2023 0:39 You are welcome. Still wondering why you are doing this as you seem to want to split the again. And dzvents already does this splitting for you.
When any of the three values change, I send the updated values to home assistant. Being able to monitor a single string for changes is easier and simpler than monitoring three values.
I simply have a variable that records the string and if it hasn't changed when the script is called it doesn't send the values.
Software:
Windows 10 Pro
HA-Bridge & Traccar
Hardware:
